The factory specs for my car (83 Shelby Dodge Charger) call for 80 ft lb torque on wheel lugs. Does that sound about right?
Thanks.
Thanks.
Bill Stevens - Mbr # 103106
BnS Racing www.bnsracing.net
92 ITA Saturn
83 ITB Shelby Dodge Charger
Sponsors - Race-Keeper Data/Video Aquisition Systems www.race-keeper.com
Simpson Performance Products - simpsonraceproducts.com
My Datsun manual calls for 75 lb-ft, so I don't find 80 surprising.
Ty Till
#16 ITS
Rocky Mountain Division
2007 RMDiv ITS champion
Racerbill--Never doubt factory specs if you are using OEM studs, lugnuts and wheels.
80 lbs is what I use on my Race Rabbit.
Tim Linerud
San Francisco Region SCCA
#95 GTL Wabbit
Convert from GP to GTL
http://www.timlinerud.com/racing/index.html
racer_tim @ yahoo dot com
I use 100 ft-lbs. But my factory spec is 90, and that's with 14mm studs (stock). 80 is very normal for 12mm studs, which I'd expect you have...
85 ft-lb on the Rabbit, w/ studs. IIRC, isn't the issue w/ over-torquing more of a problem w/ warping rotors, than anything else?
I had been tightening to 100 ft/lbs on my 12mm studs until last friday. I was checking torque on my wheels and found two studs that kept turning. I said WTF! as I tried to remove the wheel one of the studs just spun? Well I managed to remove the lug nuts, the wheel, the caliper, and the brake disk. I found that the stud had stretched and actually caused a shinking of the knurled area of the stud. The butt of the stud was even convex! those were H&R studs. ARP here we come.
Peter Linssen
SPM Volvo 740 Turbo
ITB/FP/VP1 Opel Manta
IMHO 100 is too high for 12mm studs; I run 85ft/lbs on my Pro7 with 12 mm studs and have never had a problem with wheel nuts loosening. This was with factory Mazda mags and now Panasports.Originally posted by itmanta@Sep 5 2005, 08:45 PM
[snapback]59671[/snapback]
Marcus
Marcus
miller-motorsports.com - Its always an Adventure (and woefully outdated)
1.6 ITE/SPU/ST2 Turbo Miata (in pieces... err progress)
Yep, I replaced the 12mmX1.5 with ARP 1/2-20's. I will stick to around 80-90 with those.
Peter Linssen
SPM Volvo 740 Turbo
Minor hijack -
So just out of curiosity, why did you switch to 1/2-20? ARP makes 12x1.5 studs. Did you just have a burning desire to buy new lug nuts?Originally posted by itmanta@Sep 7 2005, 09:52 PM
Yep, I replaced the 12mmX1.5 with ARP 1/2-20's.[snapback]59863[/snapback]
Ty Till
#16 ITS
1/2 is clearly stronger than a 12mm--given the same metallurgy.
"So just out of curiosity, why did you switch to 1/2-20? ARP makes 12x1.5 studs. Did you just have a burning desire to buy new lug nuts? "
The knurl diameter on the 12mmx1.5 studs were too small for my hubs. Shucks, now I cannot use my cool Zenkei forged aluminum lugnuts.
Peter Linssen
SPM Volvo 740 Turbo
http://www.rbinc.com/
Click on "wheel hardware" and then "wheel studs". There are hundreds of different designs. It may take some looking, but I'll bet you can get some.
Norm - #55 ITA, '86 MR2. [email protected]
http://home.alltel.net/jberry/img107.jpg
Website: home.alltel.net/jberry
The factory calls for 80 also on alloys for my dodge....but after seeing an unusual wear pattern on my race rims (bbs rvs and ar 24s) I called auto tire and asked what the manufacter calls for on these rims, 65 lbs....Have not had any problems since...I know it sounds low I suggest calling the maker of the rims...each alloy and the process in the way they are made are different
