Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: e-track and tire rack sources?
    Feb 2003
    1,106
    Default e-track and tire rack sources?
    i plan to install the tire rack that is made of two adjustable racks between e-track on both sides of the trailer.
    any race related sources that are fair priced?
    tia, tom
    Jun 2001
    miami, florida
    235
    FWIW, I think your best bet is www.mcmaster.com
    Search for "e track", click on one of the first couple of links and it will bring you to the catalog page for their track and shoring bars.
    They don't quote S&H on their site but you can call and confirm. FWIW they quoted me ~$12S&H to ship QTY 4 5ft pieces from Atlanta to Miami. Very reasonable.
    You can poke around Ebay also and compare what's out there.
    Good luck,
    Michael
    Feb 2002
    Little Rock, AR
    554
    The things for the tires are called "shoring bars". I got mine through Racer Wholesale (or Racer Parts Wholesale - can't remember which). For the E-track, find a local company that repairs semi-trailers. They will be cheaper than internet sources, and the freight won't eat up all your $$. I got mine from Liberty Trailer in North Little Rock, AR.
    Atlanta, Ga
    631
    Racer Parts Wholesale doesn't sell shoring beams anymore. At least the last time I called. Go to google and look up "shoring beams". You should find some. Etrack should be found at any trailer hitch place too.
    Tom Donnelly
    1970 ITS 240z
    Sep 2001
    alexandria, va
    851
    a substitute for shoring beams using common parts is..
    -e-track brackets that hold 2x4 lumber
    -2in box metal bars (hollow!)
    -3in id pvc pipe
    -a couple of bolts
    put brackets in etrack
    cut metal bars to fit
    cut pvc pipe to fit over bars
    put bar/pipe in brackets
    use bolts to hold bar to brackets
    strong, and the round pvc pipe prevents the square edge of the bar (or shoring beam) from cutting a line in your tires.
    marshall
    Mar 2001
    Connecticut
    7,381
    Anyone have any photos of what their e-track tire rack look like? - GA
    Sep 2001
    alexandria, va
    851
    [snapback]58971[/snapback]
    i'll try to take a few this weekend for you.
    Feb 2002
    Little Rock, AR
    554
    Pardon the mess . . . <_<
    Jan 2006
    10
    Nice!
    Anyone else got any pics?
    Apr 2003
    Cheshire CT USA
    220
    I dont know where you are located but this place stocks it, and if I can recall it was just under 20$ for a 12 ft section. they had a few colors available.
    They are local for me so I have no idea about shipping
    http://www.atlanticstartrailers.com/
    and I think I got the shoring bars from grainger for under 20 bucks each
    Matt Bal
    Jan 2003
    Cherry Hill, NJ
    94
    So is the only way to make a tire rack with thes is to go side to side? I guess its not so bad cause you can take them down when you get to the track? Seems much cheaper than traditional tire racks....
    Pittsburgh, PA
    1,181
    I&#39;m going to add a fold up tire rack to the side of my trailer. I dont want anything going across my trailer.
    I need to be able to walk back and forth in my trailer as we vend out of it as well.
    So anyone know of a cheap place to get these? $400 is a bit too steep for a few sqaure tubes and a hinge!
    Volkswagen Racing Equipment
    2002, 2003, 2005 NYSRRC ITB Champs
    Jan 2003
    Cherry Hill, NJ
    94
    I found these for $225.00 , I know someone that has one and it is a good unit. but still not cheap
    http://www.darkhorseracing.net/folding_tire_rack.htm
    Jun 2005
    MD, US
    1,333
    a welder, cutter, some square tubing, a tape measure and poly coated steel wire and some sweat money?
    Some hardware too for creating hinge joints and some old unused hoodpins to holt in folded fashion...
    yeah, so im no budget racing here
    James Brostek
    MARRS #28 ITB Golf
    PMF Motorsports
  15. #15
    Aug 2005
    7
    Here is a great rack that i stand behind you break it we send you a new one...made in the us by racers for racers.
    http://www.darkhorseracing.net/pit_products.htm
    Brion Gluck
    ITO/Av8 07 Mustang
    Ast Dir Av8s
    www.av8ss.com
  16. #16
    Feb 2002
    Charlotte, NC
    128
    "E-beams" that East Coast Trailer sells here locally (http://www.ectrailer.com/) in essence seems like the very same as the shoring beams. Its an adjustable box frame aluminum tube that expands from 91" to 102.3" and had spring loaded e-track clips on each side. Its load rated at 2000# for the dinky one (LOL) and weighs 20.5# per and load rated at 2500/3000# for the bigger one which weighs 23# per. And the real nice part is the cost, $34.95 for the small one, $41.00 for the big. They also sell E-track (painted and galvanized) in custom lengths - I went with painted for the cost and if I remember correctly, it was extremely inexpensive. They also sell the clip-ins that ITANorm has in the photo (the grey strap & hook type on the left side of the picture) for a few dollars a piece.
    There is also a different variant of the E-beams that I never persued that were twice the price and I cannot recall for what reason.
    I set mine up as two parallel bars and installed my e-track horizontally instead of vertically (they go into three studs each so its not going anywhere). I would have done what ITANorm did but with a curved front of the trailer, it wouldn&#39;t have worked as well in my case.
    I&#39;ll see if I have any pictures around here.
    Adam in Charlotte
    #42 ITA CRX Si
  17. #17
    Nov 2001
    WA
    50
    A friend and I made ours. Each one holds 6 wheels and they fold up when empty.
    If you&#39;re looking for e-track or shoring beams, check www.awdirect.com
  18. #18
    JohnG
    What kind of fastner did you use to keep these fixed to the walls? 6 wheels and tires is pretty heavy.
    I like yours and am thinking of makeing some similar but want to make sure when I fasten it to the wall it does not fall off the first time I drive it down the road loaded.
    Thansk SteveP
    Cheers SteveP
    "Growing Old is Manadtory"
    "Growing Up Is Optional"
    ITS Porsche 924s
    ITB Geo Prizm (For Sale)
  19. #19
    Nov 2001
    WA
    50
    Sorry for the delay. I&#39;m sort of an occational lurker here.
    The tire racks are through-bolted through the wall studs. We drilled all the way through and ran bolts with rubber washers from the outside in, and used nylock nuts on the inside.
    I can do chin-ups on them.. they&#39;re not going anywhere.
  20. #20
    Mar 2002
    Black Rock, Ct
    9,594
    Another option would be to nutsert it to the ribs/studs.
    IT-7 #57 RX-7 race car
    BMW 2003 M3 cab, sun car.
    GMC Sierra Tow Vehicle
    lateapex911(at)gmail(dot)com
