Results 1 to 3 of 3
Thread: 2.3L question
    Tampa Fla
    430
    Default 2.3L question
    took the head off, now ready to put back on and i noticed that there are no guide pins to hold the head gasket in place, whats up with that? can i just get new pins and install them?
    Palm Bay, FL
    636
    There should be hollow dowels on two corners of the head / block. If there is not, you can get some from Ford, no big deal. They are the same part as used in a 302, so you should have no problem getting them.
    HTH.
    -Marcello Canitano
    www.SilverHorseRacing.com
    Purcellville, VA USA
    902
    Most machine shops have them also. FYI
