Results 1 to 11 of 11
Thread: Where to find spherical bearings for 240sx?
Hybrid View
    Nov 2004
    East Prov, RI
    53
    Default Where to find spherical bearings for 240sx?
    ive done searches and read posts and all I could find was a company calld wes-tek and found no site from them. can anyone help me on where to find these and if there is any major modification to install? thanks
    -Chris
    Renton, WA USA
    1,625
    -Chris
    Chris,
    I have their number and contact info at work and will post tomorrow if no one beats me to it...
    As for major work to install... basically, you have to remove the entire front and rear suspensions, send the pieces to then, along with about $1600.00 for the rear (not sure about the front) to get them to do the work... Then bolt them back together.
    I hear it's a significant upgrade... Looking forward to trying it myself, though I think I'll be building the adapters myself... (just got the 20-ton press, and will be looking to get a lathe shortly... )
    Darin E. Jordan
    SCCA #273080, OR/NW Regions
    Renton, WA
    ITS '97 240SX
    Nov 2004
    East Prov, RI
    53
    holy shit thats alot of money. i have also heard its quite an upgrade but is that much noticable than uraethane?
    if yours goes well, if you would be cool with making/selling me adapters, that would be great!
    Sep 2002
    Fredericksburg, VA
    1,191
    Chris - look about four posts down in the Nissan section, Darin had a post on this same question a couple of weeks ago. There is contact info for West Tek, and another company called SPL Parts. And wow, the price of going fast has gone up! I spoke with Tim at West Tek about a year and a half ago, and he quoted me a price of around $1,250 for both front and rear setups.
    <font face=\"Verdana, Arial\" size=\"2\">i have also heard its quite an upgrade but is that much noticable than uraethane?</font>
    According to Bob Stretch, who probably has the fastest ITA 240SX in the country, sphericals are the only way to go if you want to run up front.
    Oh, and just a follow up on the previous thread regarding SPL Parts - they're having a year-end clearance on some of their parts. I just purchased a set of solid aluminum sub-frame bushings from them, and they were shipped the same day I ordered, came in 2 - 3 days later, and the quality of the parts looks excellent. Price was around $140. They also sell pre-assembled spherical bearings for around $150 a pair, which means you're still going to spend > $1K to do all sphericals from them.
    Renton, WA USA
    1,625
    The price I mentioned may have been for both front and rear... I can't recall exactly...
    Here's a great way to find out...
    Westek, Inc.
    2047 SW Topeka Blvd.
    Topeka, KS 66612
    877-West-tek
    785-235-6701
    Talk to Tim...
    I would think that Urethane would suffer from binding and drag, much the way that Rubber does. Bearings allow the pivots to truely pivot...
    My car currently has the hard rubber NISMO stuff, and it works alright, but the spericals are definately high on the "To Do" list...
    Good Luck!
    Darin E. Jordan
    Renton, WA
    ITS '97 240SX
    Atlanta, GA usa
    677
    Using sphericals in the rear is the only way to get all of the slop out, and have the suspension go through the full range of motion without binding. Period. The front LCA's don't have to be spherical. I have delrin in there, and they work fine. But the TC rod bushing should be. I am one of the few people that have machined all of my own inserts for the car. It can be done if you have a decent quality lathe. But it will require many hours of labor. I recommend that you make one each of the two or three different size inserts that you need on the lathe, and then have a machine shop duplicate the pieces to your specs. You will still have to install everything but it should save you some time and money to do it this way.
    Tristan Smith
    Buffalo's Southwest Cafe
    ITA Nissan 240sx #56
    Nov 2004
    East Prov, RI
    53
    thank or all thehelp guys. i never realized SPL does it too until no. ill go to them cuz they are well-reputable.
    since that subject is pretty much closd, what are youguys running for shock/spring/coilover assemblies? (that is if you want to say)
    Renton, WA USA
    1,625
    I have to make a correction on something I posted... I found the e-mail quote I received from Wetek and erlrich is correct... The quote I received actually said it was $1200 for the whole car, or $850 for just the rear...
    Sorry for the misquote of $1600... My bad...
    $850 for the rear really isn't too bad... as it sounds like they REALLY know what they are doing with this...
    Darin E. Jordan
    Renton, WA
    ITS '97 240SX
    Nov 2004
    East Prov, RI
    53
    well i was thinking today about the full spherical setup today and the camber issue came up: how would you correct camber with sphericals (unless urethane eccentics are being used),especially when adjustable arms are illegal?
    Atlanta, GA usa
    677
    I am not sure I understand your question, but the camber adjustment would be handled the same way. Sphericals won't affect that. If you lower the car too much you can get too much negative camber that the stock adjustment will not be able to correct, but that is a ride height, strut setup issue.
    Tristan Smith
    Jun 2001
    miami, florida
    235
    Just about everybody uses camber plates...adjustible camber and caster.
    I use Ground Control's, but the JDM stuff is an easy bolt-on.
