Results 1 to 4 of 4
Thread: Tech question
Hybrid View
    Feb 2005
    malden, ma
    11
    Default Tech question
    I'm in the final stages of getting my car ready for 4/2 annual tech at Shine. As this is my first car, I need some help on location for the fuel sampling port and if there is a specific location for the transponder.
    TIA,
    domenic
    Trussville, Alabama, USA
    1,087
    I put my transponder in the hole left by the air conditioning dryer...bent a piece os metal and attached the t'ponder about a foot off the groung...good point as there is no metal under it.
    Sample port is a high pressure hose "T" off the return line and ty-wraped in position along the left front fender. Mine will extend past the fender a good foot when loosened. Don't want to be sampling gas in a hot engine compartment. Chuck
    Chuck Baader
    #36 ITA E30 BMW
    Go to fuelports.com, Paul makes his own fuel ports and makes a hose that attaches to the fitting to sample the fuel outside the car.
    Jeremy
    Oct 2004
    Northeast
    7,031
    I have an extra high-end Test port set up if you are interested...
    andybettencourt AT hotmail DOT com
    AB
    Andy Bettencourt
    New England Region, R188967
    www.flatout-motorsports.com
