Results 1 to 8 of 8
Thread: BMW Tow Straps
    Jan 2005
    Sammamish, WA, USA
    57
    Default BMW Tow Straps
    Exctly how do I mount these?
    Do they loop around the hard crash bar in the bumper? Or around the crash shock?
    If I cut a slot in the bumper skin, they'd end up twisting through if they were wrapped around the bumper shock.
    Is the idea to remove the four bolts from the bumper shock's mount into the frame rail and loop them under the bumper shock mount, pinching them in with the bolts?
    .B ekiM
    Dec 2001
    LOS ANGELES CA AMERICA
    370
    Mike. I was in the same position as you, had the front bumper off, no big deal. And was trying to figure it out, where to cut the hole and how to run the straps (they dont look long enough). What I finally did was: Put the bumper back on, ordered these hooks from TC Design
    http://www.tcdesignfab.com/New%20Products.htm
    Not the cheapest way, but certainly the easiest way, just screw them in and I was done! They also have a fairly high "cool factor" Also if anyone wants a set of those straps I'll make them a spanking deal!
    John Norris
    ITS E36
    Sep 2001
    alexandria, va
    851
    i went the cheapest way. two nice u-bolts from home depot. drill two holes in center of front and rear bumper. stick u-bolt through, bolt nice backing plate behind bumper to spread load. if you hog out the center side of the holes, the u-bolt pushes into the bumper to be almost flush. if it is needed it just pulls out to the backing plates.
    nothing to "protrude dangerously", cheap, and you get towed from the center of the bumper, not offset like the stock locations. (ever seen a car pulled diagonally out of a sand trap by an off center tow hook? it doesn't roll...)
    marshall
    [This message has been edited by mlytle (edited February 22, 2005).]
    Jan 2005
    Sammamish, WA, USA
    57
    Thanks, John. At the very least, now I don't feel so stupid!
    Turner has a similar product here: http://www.turnermotorsport.com/html/detai..._ID=TOW/E36/E46
    but they don't say that it screws into the factory hook point. From the picture it looks like they do, but I'm not too familiar with the E46 bodied cars (like the one pictured). I wrote to them last week and haven't yet enjoyed the courtesy of a reply.
    Where did you buy yours? The tcdesign site says to contact Evosport, but I don't see the hook at their website.
    .B ekiM
    .B ekiM
    Dec 2001
    370
    That's them. I got mine from Evosport. Did it the old fashioned way, phone!
    Good luck.
    John
    Apr 2001
    Catlettsburg, KY, USA
    84
    I think the strap goes around the bumper shock in a choking type manor. There is no screwing to the factory point. Bimmerworld has these for $20 I think.
    Michael
    Jan 2005
    Sammamish, WA, USA
    57
    Thanks, Michael. But what is a "choking type manor"?
    Apr 2001
    84
    You take one end of the strap and fish it through the eye of the other end. This makes a loop that gets tighter (chokes) as it is pulled. Make sure you wrap it around the item to be choked before you put the other end through the eye. Easier to show then to explain.
    Michael
