Results 1 to 11 of 11
Thread: Header for M20 325i
    Dec 2002
    WA
    7
    Default Header for M20 325i
    I have been looking around and I find it crazy that I cannot find a header for my 325is for uner $800 bucks. Ireland sells the Stahl for $790. Then after that I have to get the thing modified for racing. I can buy a header for a 240Z for $150. What gives? What do all of you do?
    Jul 2004
    59
    Check out topend performance. I purhcased a header for my E21 this spring and it and fit good.
    Here is a shorty header for a E30 M20. You did not say what body style you are using.
    http://www.racetep.com/e30hdr.html
    Sep 2001
    alexandria, va
    851
    search classifieds for a used supersprint. the can be found for <$500.
    Dec 2001
    LOS ANGELES CA AMERICA
    370
    Brian. When I had my E30 I started with a Stahl, good header, but hung down too low, wasn't long before I demolished that. Then I got a Supersprint, much tidier and no slower. Then for my E36 I bought a system from James at Bimmerworld. Was over $2000.00 for the whole system front to back including muffler. Damm!! That's a lot of money I thought. But when I opened the box I realised that it was worth every penny. It fit great, it worked great, and it's the best looking part of my car! That system from top-end looks kind of funky. I think you get what you pay for. A good system will work well for a long time.
    Nov 2001
    Boca Raton, FL. USA; CFR/FR
    162
    I can second everything BMW racer mentioned. I had a Stahl (bought direct) on my E30 325is and it was THE lowest part of the car. I ended up welding a skid plate on the collector to keep it from getting destroyed.
    I now have the Kromer Kraft header and exhaust on my E36 and it is the nicest engineered exhaust (and nicest looking) products that I have ever purchased. Prior to the KK system I had a Supersprint and the fitment was excellent.
    Trussville, Alabama, USA
    1,087
    A couple of points of interest since I just finished looking for a header. It is correct that the Stahl is too low. I too purchased a weld-it-yourself kit and did not use it. I ended up making my own. I looked at the set Ron mentioned, but the front and rear sections are identical which makes it necessary to have the convuluted front pipe with a serious restriction where it crosses over the motor mount. Those headers are made by MSDS. I ended up making my own set (NOT INTERESTED) before I saw the set made by Ground Control. I think they will be your best bet for size/ground clearance and with a merge collector should make good power.
    I spoke with Kromer Kraft, and they will make a set for about 800 but they need a car to build a set. That was 6 weeks or so ago, so they may have engineered a set by not.
    As you can see, there is practically no easy/cheap way to header the e30. Look at what www.ground-control.com has and I think you will be pleased. IMHO, there's is the best money/clearance solution. Then you still have to build or buy a merge collector and weld everything. Good luck.
    Chuck Baader
    #36 ITA E30 BMW
    Dec 2002
    WA
    7
    Are you sure Ground Control? I thought they only made suspension parts. I cannot find anything about headers on teir website. Maybe I could get you to make me one? How much?
    Sep 2001
    alexandria, va
    851
    i had an msds header on my e30 first. fit ok, not impressed with power.
    then i had a stahl. way too low. sold it
    then i got a supersprint used. nice. well made, fit well, good power. highly recommended.
    as with bmw racer and bruce, i now have the full tilt kromer kraft header/exhaust on my e36. sweet! i wanted to just leave it on the living room table as a decoration. too nice to hide on the dirty side of the car.
    marshall
    Dec 2001
    370
    It's funny, we're all on the same page regarding the KK header. I want to get an extra 6 into1 collector I think it would look great on the dinning room table with 2 red roses in each pipe!!
    Cheers.
    John
    zracer22 Guest
    I've used the MSDS header on my car since 2001. The header has worked out perfect for me. AT $225, I can justify spending 600+ for another header that really won't gain me that much more (if any) over the MSDS. On an engine with a ported head and MAS instead of the restrictive AFM, a $600 header may be worth the extra $$$, but not on a stock motor.
    1,087
    Sorry guys, not Ground Control, Ireland Engineering Cranial Rectosis set in. Theirs are 260, and look under e30 performance, intake and exhaust. You can see they look like a good set. The set I made is very similar. Good Luck
    Chuck Baader
    #36 ITA E30 BMW
