Results 1 to 12 of 12
Thread: kill switch
    Trussville, Alabama, USA
    1,087
    Default kill switch
    how about eliminating the alternator feedback and being able to kill the motor with the kill switch. thought i had it figured out, but was not running alt. suggestions??? thanks, chuck
    Apr 2001
    Radford, VA
    216
    Easy solution. There are two wires going to the battery - one small and one large. Use a 4 pole switch and cut both, job done.
    1,087
    ok, ring up one DUH!!!! for me. one more question. have kill switch with auxillary contacts on bottom. have no idea the amperage capacity of said contacts. do you think this type of switch will work? thanks, chuck
    Apr 2001
    Radford, VA
    216
    I don't blame you - kind of surprising that it is that simple. Thank the good folks in Germany for that one. I have no idea what your switch will hold. We use the Longacre switches (no key to lose version), 4 polse have 2 big terminals and two small - one big wire and one small - haven't blown one yet!
    1,087
    james, thanks, just finished..btw, called longacre week before last, they do not carry kill switches (anymore?). bummer (as opposed to bimmer) chuck
    1,087
    james, checked function once again, kill switch works fine, but ignition switch will not kill motor. am i missing something? thanks, chuck....????
    Apr 2001
    Radford, VA
    216
    Shouldn't be an issue if done correctly. Switch closed, car functions as if no switch is present. Switch open - no electronics. Possibly another issue?
    1,087
    james....am not running cluster! jumpered wire numbers 14/16 on blue connector (C1) to entergize alternator field, and motor continues to run. when i plug in cluster, all is well. will try to isolate resistor on circuit board this weekend and see if that works...thanks, chuck
    1,087
    ok guys, finally figured out the proper procedure..on C1, the blue connector in back of the cluster, you must jumper terminals 14 and 16 with a DIODE!!! then the ignition and master kill switch work as they should, and by the way, so does the alt. 20 hours later and we have a solution. that is what makes building race cars sooooooo much fun!!!chuck
    Mar 2003
    Michigan
    15
    So, if I understand this correctly, using one of the disconnects with alternator protection, you use the large poles for the battery cable, one set of small poles for the small wire, and the otherr set to wire the resistor? Excuse the ignorance. Mechanical makes more sense....Electrical seems more like magic to me. Thanks.
    Ken
    1,087
    damn, kent, two years ago and i'm supposed to remember the big wire obviously goes to the big terminal and then directly to the starter. the smaller switch is used to switch all other functions. if you use the stock cluster, the alternator,etc will work fine. if you do not use the stock cluster, see post above and use a Schotsky diode between the wire numbers listed for correct alternator function. btw, i am a mechanical engineer..electical is mostly beyond me. i was always taught that cars ran on smoke...when the smoke escaped, the car wouldn'g run if you don't have one, go to your local bmw dealer and buy the wireing book for your year modle..INVALUABLE..even i could figure out the problem..
    Chuck Baader
    SEDIV ITS #36 E30 BMW
    Alabama Region Assistant Race Chair, Registrar
    Apr 2003
    San Jose, Costa Rica
    3
    <font face=\"Verdana, Arial\" size=\"2\">We use the Longacre switches (no key to lose version), 4 polse have 2 big terminals and two small - one big wire and one small - haven't blown one yet!</font>[/b]
    James you are talking about the Longacre part number 4578 Battery disconnect switch only - 4 terminal?
