Results 1 to 4 of 4
Thread: E-36 OIL COOLER
    Dec 2001
    LOS ANGELES CA AMERICA
    370
    Default E-36 OIL COOLER
    Hey E-36 guys. Do any of you run an oil cooler with the motorsport filter housing?
    John Norris
    E-36 in progress
    Apr 2001
    Radford, VA
    216
    Such luck! I just got a call from a customer that is bringing in a 525 that has an oil cooler for an engine swap this weekend. We will pull off the housing and I should be able to answer your question early next week.
    James Clay
    http://www.bimmerworld.com
    Engineered BMW Performance
    World Challenge/SCCA/BMWCCA Racecar Rental
    (540) 639-9648
    Lost Gatos, CA
    119
    If you are inquiring for ITS useage, I don't think an oil cooler is needed. I have run in very hot conditions (>100 F), and the oil temp hasn't exceeded 220. Under more normal temps, it hovers nicely between 180-200.
    Maybe others have different experiences.
    Dan
    Apr 2001
    Radford, VA
    216
    I agree. Also, I can't help much. The 525 that came in has a filter housing for the oil cooler without a vanos fitting - I have no idea what it originally came from!!!
    James Clay
    (540) 639-9648
