Results 1 to 5 of 5
Thread: Euro Oil Cooler
    Jan 2003
    Grosse Pointe Park, Mi, USA
    21
    Default Euro Oil Cooler
    Has anyone installed the euro oil cooler on a US e36? From one of the other forums, someone mentioned that the euro supplies oil to the vanos in a different method. Apparently, you have to retap the filter housing oil temp sender for the US vanos supply. I have the parts but no instructions and I would prefer to prep the housing before tearing into it. Any comments from someone who has done it? Thanks!
    Ken
    Tijeras, NM
    579
    If it aint broke, don't fix it. Honestly, I suspect you'll cause more problems than you fix. Just run synthetic oil.
    Jan 2003
    21
    Anyone know? Thanks.
    Ken
    Mar 2001
    6
    I don't remember having to retap the housing, I just bolted it on. You should take off the vanos oil line an try it before you put it in the car.
    GKR_17 is right when he says you probably don't need it. It takes 10-15 minutes under race conditions just to get the oil up to temp in my car.
    Lost Gatos, CA
    119
    For IT, I can't imagine needing a cooler! Even on a scorching day, the oil rarely exceeds 220.
    To answer the question, though, Euro motors come pre-tapped for the oil cooler. To install one in a US motor, you can get a tapped oil distribution block from several people (or so I've heard). One BMW tech suggested that the cheapest alternative to the expensive euro cooler (BMW's) would be to take a castoff automatic tranny fluid cooler. It just bolts in front of the radiator.
    Dan
