Results 1 to 4 of 4
Thread: IT Specs
    Oct 2002
    OR
    2
    Default IT Specs
    I am about to get a license and am curious about the IT specs. I have been on the track (PIR), autocrossed and hillclimbed for the past (2) seasons in the DSP category. Is IT close to that in spec?? I have an '85 eta.
    Apr 2002
    Bridgewater, MA USA
    1,300
    It's close. Stock intake, carb (unless specified in the GCR), and/or FI must be used. Only changes on FI are BEFORE the AFM. Suspension is pretty much the same. Any swaybars, shocks, springs. Wheel width is limited and diameter is specified by car.
    Noise is governed by track.
    Should get you started while your GCR is on the way.
    AB
    Andy Bettencourt
    06 ITS RX-7
    FlatOut Motorsports
    [email protected]
    Oct 2002
    OR
    2
    Thanks. So are coilovers permitted or only upgrades to springs and shocks on the OE setup?
    Apr 2001
    Radford, VA
    216
    Non threaded, non remote reservoir shocks. A front sleeve style coilover is allowed, rear spring location cannot be changed.
    James Clay
    http://www.bimmerworld.com
    Engineered BMW Performance
    World Challenge/SCCA/BMWCCA Racecar Rental
    (540) 639-9648
