Results 1 to 5 of 5
Thread: 2002 Rust
    Oct 2001
    Cumming, GA
    59
    Default 2002 Rust
    Well my ITB 2002 project car has a growing amount of rust.
    When I got the car it appeared to be a small hole in the driver's side floor. When I pulled the carpets some of the floor went too.
    Now several more holes have appeared from the work going on with the car.
    Last night I noticed some rust on the inside of the frame rail.
    At what point do I call it a loss and dump the car? What is safe to replace in the floor with the knowledge the cage has to attach in this area?
    My goal is to build a safe car...but this worries me.
    Dennis
    Tyrone, PA
    203
    You need to completely stip the floor material down to the metal to evaluate the car. Floor sections are available from Maximillian Importing, and properly repaired, would be strong enough, if you tie the cage mounting point into the inner rocker panel. How are the shock towers? How are the front frame rails?
    Dave
    O=00=O
    Oct 2001
    Cumming, GA
    59
    Shock towers in the rear are excellent. In the front they seem to be okay but that area is fairly dirty and hard to tell at this point.
    I think the front frame rails are okay but I need to take a closer look this weekend.
    Dennis
    Dec 2001
    LOS ANGELES CA AMERICA
    370
    Ahh Rust!! The good Lords acid dipping!! Thats why I moved from England to Southern California. I'm still racing my '70 2002 with hardly a spot of rust. Good luck with you project. Mail me at [email protected] If you need some help.
    Sep 2002
    2
    Check under the master cyclinder the brake fluid loves to eat the frame rail. Can be hard to see, poke at it with a screwdriver.
