mark, you mentioned the M3 front sway bar mounts..if you plan to adjust ride height to around 5", you need to shorten the front strut tube. to do this, you must mount the sway bar mount lower on the tube, which moves it too far from the sway bar. you end up with a cantilevered bolt to attach the linkage, and that is not rigid. bmp makes some neet sway bar mounts for the stock position that work very well. good racing
Chuck Baader
SEDIV ITS #36
E30 BMW
