well the new clutch is in and the flywheel resurfaced, the old disc and throwout were blown to pieces. also is appears that the pilot bearing was loose in the shaft, and that the shaft itself not the bearing was the reason. it was obvious that someone had been in there before (im not the first owner) and that the pilot bearing is no longer properly secure. we secured the bearing as best as possible knocking it in and using loctite. So although my clutch is all set, i might be looking at more problems in the fututre.
thanks for all the help
Matt Rooke
89 RX7
