Hey Chris,
I've actually got enough parts.
I've got:
1 early stock pressure plate
1 early 4 puck non sprung clutch
1 late stock pressure plate
1 late HD pressure plate
1 late 4 puck spring hub clutch
and flywheels in both sizes.
The issue is that I really like my lighterweight flywheel, but there is not clutch feel with the 4 puck andstock pressure plate. The clutch also releases *very* high. Much higher then the previous setup (Late model HD prressure plate, spring hub clutch)
I'd like the clutch feel of the old setup, and am pointing att he presure plate right now.
Marcus
