Results 1 to 10 of 10
Thread: quicker removal of 1st gen front rotors
    Bethlehem, Pa
    26
    Default quicker removal of 1st gen front rotors
    Does anyone have a trick for speeding up the job of removing the front brake rotors on a 1st. Gen RX-7. I have ground down a 14 mm wrench to fit better behind the bracket that holds the caliper, but it is still a pain to get at it. Any ideas would be greatfully appreciated.
    John MacKechnie
    Jun 2003
    New Milford CT usa
    21
    I found that if I pulled down on the top of the bracket after I took the top bolt out and move the bracket up and down it loosen the lower bolt so I could get an open end wernch in to remove it. I had to use some persuasion to get the bracket to move but once it did I had no problem getting the bolt out.
    Lou I
    NER ITA #79 RX7
    Jan 2002
    Williamsport, PA, USA
    130
    John,
    That bolt is a PITA. I use a 14mm long box wrench and I wedge a square shafted Craftsman screwdriver behind it to hold it on. I am able to get the box wrench on far enough on that I can break it loose, and I then use the open end to spin it off.
    Bill Emery
    Glen Region
    ITA#23
    Jackson, MS, USA
    189
    When I put my brake ducts on I ground down the edge of the caliper mounting bracket so a box wrench would fit the bolt head. Only had to do this on the top bolt. I took off very little material on the bracket. It seems to work pretty good. I can change a rotor in about 15-20 minutes if everything else goes well.
    Drive well.
    Wauwatosa, WI, USA
    2,658
    Ditto to to the method used by Bill. Works great.
    Have Fun
    Apr 2001
    Hubbard, OH, USA
    260
    I remove the rear bolt from the bottom of the strut, loosen the front one, and wa-la rotate the assembly and use a socket on that nasty little bolt.
    I too can change the rotor in ~15 minutes, although the first time on an aquired Rx7, often takes longer
    Jan 2004
    Camas, WA
    531
    I use an identical procedure; the last one took ~20 minutes including installing a new inner bearing. . . .
    Marcus
    May 2002
    Castro Valley, CA
    156
    Go to Sears and buy a combination 12/14 mm OFFSET box end wrench. It has a 12mm 12 point box end on one side, a 14mm 12 point box end on the other. Each box end is offset ~1/2 inch from the handle. It fits right into the caliper bracket and gives your knuckles extra clearance. Also handy for those pesky drive shaft bolts!
    Tak
    #29 ITA SFR SCCA
    Guest
    buy the turn in spacers from G-Force and the problem is gone.
    St. Louis, MO
    1,215
    Ding! (Lightbulb just turned on upstairs) That's why the calipers came off so quickly on my new RX! As I was removing them I was thinking "hmmmm, this is going awfully quick."
    In my defence, the spacers were already installed when I bought the car.
    Scott
    It's not what you build...
    it's how you build it
