****Copied info****
****WIth the NA rotary, the highest octane you should use is US pump (AKI) 87, typically RON 91 outside the US, no matter how heavily your engine is modified. Octane in excess of any engine's actual requirement is always wasted. The issues of purity and additives in more expensive fuels are entirely separate issues. There's no reason not to want either in a NA rotary.
The rotary engine's high turbulence combustion chamber provides a very high resistance to detonation. Its duration of combustion is also longer, remembering that the rotors turn at 1/3 of the tachometer reading, and the slow burn* of high octane is undesirable in it. Pump 80 octane is more than sufficient for most of them. Best power and mileage is usually produced with the lowest available octane.
Many serious rotary racers bring their own low octane gasoline to tracks that supply only racing gasoline. From "How to Modify Your Mazda RX-7", by Dave Emanuel and Jim Downing, HP Books, 1987, ISBN 0-89586-383-9, p 47-8:****
Have Fun
