12A timing tips?
The new junkyard 12A ran great for a weekend at Road America. For that weekend we (john the wrench and I) just left everything factory spec to make sure we got through it. Now that we know the motor runs I'd like to experiment with advancing the timing. It would be great if we had one of them high tech timing lights with an advancing setting, but... um... we don't.
Can a nice timing setting be found just using a 'joe average' timing light and does anyone have any timing tips? I know that it would take a dyno day to get this correct, I'd just like to get a little more power out of the engine for this one last race of the year. (Blawkhawk oct. 11/12th, see you there).
Ben.
**(Blawkhawk oct. 11/12th, see you there).**
Ok, sounds good to me. Bring your tent heater.
Have Fun
I gotta start saving the info I come across, but I'm almost positive that you DONT want the fancy dial type timing lights. I'm pretty sure the timing topic has been covered here before....
Scott
It's not what you build...
it's how you build it
<A HREF="http://www.pfmracing.com" TARGET=_blank>
www.pfmracing.com </A>
You are right about the dyno being the way, but it certainly wouldn't take a whole day.
Do a base line run where you are currently set, then do one with the dist. moved just a little bit each way. You can then see which direction to go in, and maybe do 2 or 3 more runs. A run takes all of 2 minutes, and you can do the whole thing from on trailer to back on trailer in 2 hours max.
G. Brooke Carter
Wheat Buckley Racing
# 10 Challenge Car
2003 Class Champion
Calgary, Alberta
At the 1st generation RX-7 site you can find all the information you wanted to know about timeing a 12A engine.
www.mazspeed.com
Drive well.
Well that's one site I didn't know about. Cool! All taken care of.
Thanks! See ya there David!
- You may not post replies
- You may not edit your posts
Forum Rules
