Results 1 to 5 of 5
Thread: OMP Removal Legal for ITS?
    Oct 2002
    Wandering the USA
    1,341
    Default OMP Removal Legal for ITS?
    I'm swapping in a different engine ('88 RX-7), so this would be the best time to deal with this. I'd like to remove the oil metering stuff (running premix). Can I do that, or do I have to leave it in place?
    Marty
    Marty Doane
    ITS RX7
    CenDiv WMR
    Jackson, MS, USA
    189
    This question has come up a time or two. I can find nothing in the regs that says you can remove it. However, it doesn't say it has to work.
    I have seen cars with the pump removed. I haven't heard of a protest on this item. The definitive answer is get an official ruling from SCCA in writing.
    I run ITA and just left it on the engine. I also run premix.
    Drive well.
    Oct 2002
    Wandering the USA
    1,341
    What's the method of "adjusting" it (so it doesn't work)?
    Marty Doane
    ITS RX7
    CenDiv WMR
    8,607
    ... However, it doesn't say it has to work. ...
    Sure it does: "Other than those specifically allowed by these rules, no component or part normally found on a stock example of a given vehicle may be disabled, altered, or removed..." (17.1.4.B, par. 1)
    Unfortunately, the only way to get a truly difinitive answer is not only to protest and get an at-track ruling, but to have that finding appealed.
    Kirk
    Jackson, MS, USA
    189
    I stand corrected!!! However, the pumps do go bad. I have never checked mine to see if it is working. I just assume it is because it is a stock motor. Still, I premix. I run dino oil in the engine and Yamalube "R" as premix. Never had a problem.
    Drive well.
