Results 1 to 7 of 7
Thread: 2nd Gen Tire Pressure
    Feb 2002
    Gainesville, GA
    493
    Default 2nd Gen Tire Pressure
    I'm sure that this has been answered before, but what are people running for cold pressures, front and rear, running the 225 Hoosiers on a 2nd gen RX7?
    Thanks for the info.
    Rory
    Apr 2002
    Bridgewater, MA USA
    1,300
    Rory,
    It would be a dis-service to you to answer without knowing camber, caster, spring rates and shock valving.
    AB
    06 ITS RX-7
    FlatOut Motorsports
    www.flatout-motorsports.com
    [This message has been edited by ITSRX7 (edited January 21, 2003).]
    Feb 2002
    Gainesville, GA
    493
    I realize that other factors play into the equation.
    So, Andy, what camber, caster, spring rates, shock valving, and tire pressures are you using?
    Thanks,
    Rory
    Apr 2002
    Bridgewater, MA USA
    1,300
    We have a few cars on the team but Nick's was developed to it's current state:
    650lb F 375 lb R
    Camber is track specific
    Valving is custom for 'up to' 700lb rates
    My car should look like a typical ITS RX7:
    500lb F 325lb R
    Stock Koni valving (max spring rate for this
    valving)
    Our Hoosier pressures were in the 36 degree cold. This showed us the best pyrometer readings at our tracks. We now run the GoodYears.
    AB
    06 ITS RX-7
    FlatOut Motorsports
    Feb 2002
    Gainesville, GA
    493
    Andy,
    Thanks for the info!!
    Anyone else agree/disagree?
    Rory
    Apr 2002
    Bridgewater, MA USA
    1,300
    Live by the pyrometer, Obi-wan. Everyone will be a little different.
    AB
    06 ITS RX-7
    FlatOut Motorsports
    May 2002
    Indianapolis, IN
    255
    Andy is right. Tire temps tell the tale. I run a softer spring/shock setup and my pressures for Hoo Hoo's are a bit lower than what Andy runs.
    Pauly D
