Results 1 to 3 of 3
Thread: Fuel Flow
    Jul 2002
    Montgomery, AL, USA
    18
    Default Fuel Flow
    I know just enough to be dangerous,need help!fuel cell is in, whats the best setup from cell to engine,top or bottom, filter, pump, etc. sometimes i forget to say but thanks for the help
    Nov 2001
    PARKER,AZ.USA
    43
    I spent alot of time on this very topic, but as usual, simple is ...well ...simple. on my 89 2nd gen, I used 2 cheap NAPA brand stock replacement electric pumps from 1st gen 13-b car ran in series in the tub just left of the cell, w/a pre filter on the intake side, and the stock wire loom plug grafted into the new plug.Then as life would have it I ran one pump at first for a week of testing and on a cold night ,13 miles out in the middle of nowhere I lost presure for some unknown reason and after 3 + hours trying to get a cell phone signal I got home. After hooking up the 2nd pump so they were both on I've yet to have a failure. I did use the stock line to the front, and instead of using braided steel, when needed, I used a great product called Push Lock, It's a barbed fitting that will last and seal as long as you want it to and it is strong and alot cheaper than stainless garb,all my oil lines are push lock also.If you want photos let me know. [email protected]
    Aug 2001
    Alpharetta, ga, usa
    145
    Spend the money and do it right!
    Get a Carter fuel pump (1 to 4 psi) and a Fram inline fuel filter with replaceable elemenet. Also, spend the money and get a sump collector (check balls and all) and mount it in the bottom of your fuel cell. Get braided line and run it all the way through the car to a Holley Fuel Pressure Regulator. Don't forget to put your fuel test port (required by the GCR for everyone effective this last year) in. I suggest putting it close to the cell.
    Let me know if you want a link to see pictures of my setup as it was being done last year.
    Balz
    #67 IT-7
    www.balz.myip.org
    "I live my life one Apex (seal) at a time"
