Results 1 to 6 of 6
Thread: Rear Camber on 2nd gen RX-7
    Apr 2002
    Toronto ON Canada
    6
    Default Rear Camber on 2nd gen RX-7
    Has anyone had or solved problems with the rear camber being different between L and R rear wheels?
    I get a half degree difference all through the adjustment range (with a Mazcomp adjuster) between the two sides. Trouble is, I can't find anything that looks damaged or bent in the subframe - trailing arm assembly. What am I missing? (mutter mutter...)
    Thanks in advance everyone,
    Curtis
    Floyds Knobs, IN
    1,093
    Mine was off a bit too. Not 1/2 degree though. Might be ride height. With you in the car race ready check the ride height on both sides. A significant difference will effect camber. Mine was like .2 degrees or something. I just left it.
    Chris
    Oct 2001
    Rancho Cucamonga, CA, USA
    1,066
    Curtis,
    The ride height is a great starting point, not real familiar with the camber curves of a second gen, but would think it would have to be noticeably different to equal a 1/2 degree change.
    If you are using a "bubble type" unit, is the floor perfectly level? If the floor appears level try pulling the car "nose in" and measuring and then back in and re-measure, did the camber measurements stay the same? If not, your floor is not level enough and you need to compensate for the slope in your concrete or measure with a square and vernier.
    Happy aligning!
    Bay Shore, NY
    351
    Make sure that the lateral links are not bent and that both ball joints move freeley. These are often overlooked and can often mess up your rear suspension gemotery and cause suspension bind. Also make sure that the rear subframe bushings are ok. If the rear subframe is crooked it can also make alignment difficult.
    With all that said, mine is also off a little. The guy at the alignment shop said they are always different.
    Floyds Knobs, IN
    1,093
    IMHO it's cool and all to be able to adjust both side with one turn of the wrench but the whole design is not the most impressive thing. Looks like it'd be very easy to have a bind or slop in the subframe bushings. Making accurate and repeatable setting hard to achieve. Just my thoughts.
    Chris
    Aug 2001
    Alpharetta, ga, usa
    145
    I am almost embarrased to say that we pulled mine out and heated/bent the whole Rear assembly to set 1 degree negative.
    Having a LEVEL FLOOR is a must!
