Results 1 to 2 of 2
Thread: Help 2nd gen oil cooler fittings
    Jun 2001
    Louisville, Ky.
    7
    Default Help 2nd gen oil cooler fittings
    I'm in need of the size of the ports in a stock cooler so I can get new AN fitting.
    Broke mine at race need one for Sun.
    Floyds Knobs, IN
    1,093
    The two in the oil cooler are 18mm x 1.25 (I'm pretty darn sure). If you happen to be running -10AN lines, you can order the adpapters from Mazdatrix or Racing Beat online.
    Chris
