Results 1 to 8 of 8
Thread: Best Coil Overs to Use?
    Dec 2002
    16
    Default Best Coil Overs to Use?
    What are the best coil overs to use in the ITA class? I just ordered some Koni Adjustable shocks, and would like to upgrade the rest of the suspension.
    thanks
    Jun 2001
    North Canton, Ohio
    103
    You can not go wrong with Ground Control!
    Dan Beeson
    [email protected]
    Dec 2002
    16
    is there a big differnce between the cheap sets you see on ebay, and the more expensive one? I do have koni adjustable shocks, so i want to go with whatever will work best with them
    steinbach, mb, canada
    242
    the cheap sets on ebay typically have mystery spring rates.
    With Ground Control you can order custom rates/lengths
    Apr 2002
    Monroeville, PA USA
    541
    You cannot go wrong with either the Ground Control or Skunk2 sleeves. The GC's can be machined for the Koni "yellow" sport shocks whereas you will need to buy the adaptor plates from Koni to use with the Skunk2 sleeves. I am using the Skunk's and they are justfine. Both companies use Eibach ERS springs and will tailor the rates to what you need, based on their experience and your input.
    Happy holidays
    '89 CRX Si-SCCA ITA
    '96 Civic HB Just cruising daily
    '99 Prelude=a sweet song in motion
    Aug 2001
    redondo beach, ca
    492
    I dont believe Skunk2 uses Eibach Race Springs.
    Just buy the GC kit if youre totally set on adjustable springs.
    Sep 2002
    Florida
    54
    OPM Motorsports have a good coil over system.
    Louis
    Apr 2002
    Monroeville, PA USA
    541
    Tyson-I cannot argue the point except to say that the part numbers I have from Skunk for 2 completely different spring packages are the same basic numbers that Eibach uses. For what it is worth the springs are red with white numbering indicating the ID, Length, Rate.
    '89 CRX Si-SCCA ITA
