Folks:
I inherited an 89 CRX Si from my gf to convert into racecar for the 2004 season. (I currently race a 74 Opel in ITB but it's on its last legs..)
Anyhoo, the CRX used to have some starting trouble, and now it wont start. Here's the sequence:
1) Car turns over pretty good. New starter and battery in good shape.
2) I could smell fuel in the exhaust when I turned it over.
3) Since it had 180K miles I suspected poor compression. So I checked compression. Except for cylinder 2 (which only has 90 #) the other 3 have 150#.
4) Next I checked for spark. No spark ! Plugs and wires were real old so I replaced them. Still no spark.
5)Ignition coil is fairly new. I checked resistances. Look good.
6) Replaced ignition module. Still wont start.
7) All wiring seems in good shape. Not worn out or cut.
Right about this time I'm out of ideas. So I looked up the Haynes manual for trouble codes from the ECU. It said that the LED must be shining if ECU is OK. The LED flashes briefly as I turn the key in the ignition and then goes out. Doesn't set any other codes. Could it be the problem with the ECU ? Any other suggestions ?
Bhima
