Results 1 to 6 of 6
Thread: Pocono gearing
    Sep 2001
    10
    Default Pocono gearing
    Thinking about running the Pocono event in May. Was wondering, with the new configruation, will I "run out of gear" with my 4.73's in my ITA CRX?
    Apr 2002
    Monroeville, PA USA
    541
    I will hazard that you will be a bit short as the typical Final Drive ratio is 3.88 or 4.25 for an L3 transmission (model dependent). The long course configuration will produce top speeds in the 120 range. The South Course is a bit slower as the fast segment is in Turn 1 (IMO). Many of us were over 100 mph before braking for the left into the infield portion.
    Hope this gives some help.
    Apr 2002
    Monroeville, PA USA
    541
    Originally posted by jc836:
    I will hazard that you will be a bit short as the typical Final Drive ratio is 3.88 or 4.25 for an L3 transmission (model dependent). The long course configuration will produce top speeds in the 120 range. The South Course is a bit slower as the fast segment is in Turn 1 (IMO). Many were over 100 mph before braking for the left into the infield portion. This was with my Prelude.
    Sep 2001
    Oviedo, FL
    115
    Hey there JJohnston. I am not from that region nor have I driven that track. But, I do have a 4.73 final drive in my ITA CRX and we run Daytona. There is just enough gear left going into Turn 1. It is at about 6700-7000rpm depending on a draft at Turn 1. Coming out of the bus stop on the back half of the track to turn 1 is a loooooooongggg way around. I dont think there is a longer straight at any track that I am aware of. Aproximately about 125-130 mph. give or take a few. Hope this helps you out.
    --Mike
    Jun 2001
    Warwick, New York
    941
    Has anybody raced with the 4.2 and a quaffe(opm etc) on a long track. I am thinking of trying it on like Pocono, or the Glen.
    Dec 2001
    Eugene, Oregon
    128
    Jc-- Have you or anyone out there got a rough idea what the time improvement might be on a typical 2 mile course going from the stock Acura I believe 4;40 to the 4;73 gears?. My car is a 94 GSR and I am in third gear alot and down in the 5 grand range. I realize I will have to use 5th gear
    e more. Seems the lower gears should help alot.
