I am about to change the brake master cylinder. I would like to sanity check myslef before I start the work.
0. Empty the resivior
1. Disconnect the lines from the master cylinder
2. place pan under the master cylinder to catch any brake fluid that spills
3. Remove the master cylinder from the brake booster.
4. replace the new master cylinder
5. refill the resivior with brake fluid
6. bleed the brakes.
Is there a step I am missing? I have a shop manual and that looks like all there is to it.
Thanks for the advice,
Greg
http://www.ita.hondapowered.com
