Fuel Port Hardware for 88 CRX
what hardware are you all using for Fuel Port setups on your hondas? I am planning on using and HVAC schreader valve attached to my fuel filter pressure relief port ontop of the banjo bolt & a femal fitting on a short hose for samples. But wanted to check w/ you all for other options before I hooked it all up.
thanks
dave w
heh, check the reply on honda-tech. schraeder valve on the filter is the common setup ive seen.
- You may not post replies
- You may not edit your posts
Forum Rules
