Results 1 to 6 of 6
Thread: Miata wheels? 14x6
    Aug 2001
    redondo beach, ca
    492
    Default Miata wheels? 14x6
    Hey, with a 45mm offset, will the OEM Miata wheels which are 14x6 work on a CRX right? I know theyre 4x100 too. The advantage would be, depending on year, theyre really lightweight at 10-12lbs and with so many spec miatas out there, theres gotta be some affordable sets laying around.
    Sep 2001
    Oviedo, FL
    115
    Yes, they should fit. I have some(hint,hint).
    Just make sure that they clear the brake calipers when they are torqued.
    --Mike
    Dec 2001
    steinbach, mb, canada
    242
    I've heard you have to machine the center hole to be larger... But I can't say for sure
    Tyson, ask on crx.h-p, it comes up there every once in a while, someone will know
    Southfield, MI
    564
    The 8 stock Miata wheels laying by the Spec Miata I'm working on are 14x5.5 not sure if there were other wheels that were 6" wide, but these are 5.5".
    Mar 2001
    Winter Park, Florida, USA
    383
    I have a set of the steal wheels, the ones with hubcaps, and the centers are too small. However, I don't know if the aluminum one's have the same problem or not.
    Richy Gonzalez
    ITA 89 CRX - 2002 Season
    Apr 2002
    Vancouver Canada
    24
    I just obtained those same wheels
    Everything is correct but you have to machine the centre out to clear the stub axle spigot
    WC
