Max wheel size for this car would be a 15x7. Anyone here have experience fitting this size package on a Coupe? What is the bolt circle on the EX?
Kirk
Kirk
I have a CHB but the bolt pattern is 4x100mm. 40mm off set. 15x7 wheels are so darn plentifull. You can get Rota wheels (Spoon Sports imitation) and many other 15x7 wheels cheap almost anywhere.
I think for ITS, the car has to run the 14's. I know for Limited Prep. Prod., it can run the 15's... But either way, the bolt pattern s/b 4X100.
How long before you come out and 'play'?
Matt Downing
www.downingracing.com
Hmmm. Double-checked and the listing in the ITCS line for the EX indicates 15" wheels but 14" for the Si. They both came with 14" stock, right?
The valve sizes are indicated as different too. Perhaps all of the numbers are suspect, since the EX is listed with a 2621.0" wheelbase (218 feet or so)!
I am done with classes in May. Just that little dissertation thing to take car of...
