Results 1 to 3 of 3
Thread: help - removing wheel hub
    San Jose, CA, USA
    456
    Default help - removing wheel hub
    As my saga continues...
    I now have the proper replacement wheel stud. My issue now is removing the wheel hub. Can someone tell me how to do it? I have removed the spindle nut. I have gotten as far as removing the brakes and rotor and I can see the hub. My next guess is to use a special tool to remove the hub? I am right?
    San Jose, CA, USA
    456
    my car is a 94 Civic.
    Sep 2001
    57
    remove the upright knock the stud out it probably won't pass the material behind it grind a small groove just enough so that the stud passes then install new one you will need a press or special tool if you want to remove hub we do this to our uprights to make it simple if its just a stud we need hope yhis helps
    ita#10crx
