Results 1 to 6 of 6
Thread: Nitto drag tires
Hybrid View
    17
    Default Nitto drag tires
    Has anyone tried Nitto's drag radial tire on a crx on the track???
    Mar 2001
    VA
    113
    Not personally, but a friend did use them for a season of autocross on a CRX. Worked fine, just required lots of pressure to stop rolling over. That soft sidewall might be an issue at the track where the speeds are higher, but not sure.
    Dec 2001
    steinbach, mb, canada
    242
    I'd say if you can avoid using them, do. You don't hear a lot of good things about nitto tires...
    Flagtown, NJ USA
    6,335
    Why in the world would you want to use a tire designed for drag racing in an Auto-X or Road Racing application?
    MARRS #25 ITB Rabbit GTI
    17
    The reason forthe question was Nitto now makes a road race version but only in 17" & 18"sizes. The Nitto is a dot tire and not a normal wrinkle side wall drag tire. At least the price was right. I run Toyo's and think there great.
    Nashville, TN
    30
    Even though the Nitto is a DOT approved tire it still has a much weaker sidewall construction than a street tire much less a DOT approved road race/autocross tire. Not a good thing to run on the street on a normal basis much less at the track.
    Later,
    Jason F.
