Results 1 to 15 of 15
Thread: Changing Rear Brakes
    Jul 2005
    INDIANAPOLIS
    28
    Default Changing Rear Brakes
    Morning
    just bought my first ITB car, 82 Scirocco and was wanting to change to rear disc brakes . Rules aren't clear about this modification.
    Dennis
    Jul 2002
    Billerica, MA
    272
    Unless the car came with it or it shares a spec line in the ITCS, you cannot change it.
    Short answer: nope.
    Welcome to the maddness. Where are you going to be racing?
    ~Jason
    Jason
    ITB 17 (NER SCCA)
    VW Scirocco
    Jul 2005
    INDIANAPOLIS
    28
    I Live in Indy, not sure what region that puts me in. Just bought the car Sunday and haven't done alot of research yet! Should I have any concerns about the front hubs,I have heard that they break often.Where are you located.
    Jul 2004
    Centreville, VA
    13
    you are correct - the front hubs are the achilles (sp?) heel of the A1 style VW's. I change hubs and bearings every season and always before an out of town event so theres no suprises away from home.
    Good luck with the VW! Welcome to the ranks -
    www.teamdriverswanted.com
    Mar 2003
    Somewhere in NC
    969
    I raced an A1 GTI for a while and also found the front hubs to be a broblem if not changed out regularly...they are easy to find and not real expensive to keep spares around...generally i found the first sign of a failing hub to be no brakes...it pushes the brake pads in from the rotor deflection and you have to pump them...fast!!! as far as rears go...i did not find rear discs real neccesary as the drums, properly adjusted, are easy to deal with and reliable...you wouldnt gain much by changing them anyways...spend your money on stuff that will give you good legal gains. Good luck!!
    Evan Darling
    ITA Integra
    Jul 2002
    Billerica, MA
    272
    Well you've come to the right place. Look in the archives for Hub related threads. Most people change the front hubs at the beginning of the season and they last fine. There are some good sources for equipment and advice.
    My favorite is Shine Racing www.srsvw.com
    But there are others. BSI is one of them.
    Go to the track even before you race and befriend some other ITB VW folks. They can help you out.
    Go over the car like you were building it yourself. Just because someone else thought it was done right, and/or legal, does not mean that it was.
    Don't worry about the drum brakes, we don't use them much Just stomp on the go pedal!
    If you want to contact me offline itracer (at) gmail.com
    Jason
    ITB 17 (NER SCCA)
    VW Scirocco
    Jul 2005
    INDIANAPOLIS
    28
    two more questions if I may , front stress bars - if I read the rules correct we are allowed only one , either upper or lower . I have been looking at the eurosports 4 point lower stress bar,and their upper strut brace. Which one would be the best. And we have to use the stock rotors, no drilled or groved. Are Hawk pads a good choice for the track. Thanks for your help. If anybody needs any stock VW parts call me
    800-968-3886 @ 7827.
    Dennis
    Indianapolis
    Mar 2003
    Somewhere in NC
    969
    The lower brace does the most......
    Evan Darling
    ITA Integra
    Jul 2002
    Billerica, MA
    272
    I am not convinced that the four point lower bar is legal on the 8v cars. Read the rules and make your own judgement. I personally would go with the two point Lower mount.
    ~Jason
    [This message has been edited by itracer (edited July 06, 2005).]
    Apr 2001
    Belmont, CA USA
    1,098
    BUT you can have a lower sway bar mount, that acts just like a stress bar.
    I have both on the car, now and when it was an ITB car.
    Change out the hubs every year. Take a set off, have it magniflux'd and have new bearings installed. They install your "spares" and put the new ones in the "spares" box. I travel with both side control arms, hubs, disks, 1/2 shafts, CV joints (inner) calipers, struts to each race. I can rebuild a corner @ the track, if needed.
    Tim Linerud
    San Francisco Region SCCA
    #95 GP Wabbit
    racer_tim @ yahoo dot com
    [This message has been edited by racer_tim (edited July 06, 2005).]
    Flagtown, NJ USA
    6,335
    Originally posted by DENNISC020:
    Morning
    Uh, that's actually an ITC car. '82 was the first year of the Mk II Scirocco (same chassis as the Mk I, just different bodywork). The cars came w/ a 1.7 FI motor, solid 9.4" front rotors, rear drums, and a wide-ratio 5-spd trans. They also came w/ 13" wheels, but that doesn't matter w/ the recent rule change.
    If the car has any GTI stuff on it (1.8 motor, vented front rotors, close-ratio trans) it's not a legal car, even in ITB. This is due to the VIN# rule, and the fact that there's a digit in the VIN that indicates what size motor (1.5/1.6/1.7 or 1.8) came in the car. Not to mention that the '82 never came w/ a 1.8 motor.
    Silly rule, but that's the rule.
    SCCA 279608
    Jul 2005
    INDIANAPOLIS
    28
    well crap ! it has a 1.8 not sure about trans. did I buy a car that can't be raced.
    Apr 2001
    Belmont, CA USA
    1,098
    Just say it's an '83
    Unless you plan on going to the AARC, I wouldn't worry about it. Just make sure to take out the NOS bottle. That would get most people's attention.
    or convert it to Limited Prep G Production
    Tim Linerud
    #95 GP Wabbit
    Jul 2005
    INDIANAPOLIS
    28
    NOS - I DON'T HAVE NO STINKING NOS !
  15. #15
    Flagtown, NJ USA
    6,335
    Not legally in IT (except ITE), in its current configuration.
    SCCA 279608
