Results 1 to 6 of 6
Thread: Need help, wierd problem
    Columbus, Ohio
    53
    Default Need help, wierd problem
    Ok, first race of the year this past weekend at IRP, and had a really strange problem all weekend
    The car is a 83 Rabbit GTI, I just converted it from ITB to GP, the only change motor wise was the bottom end, made no other changes
    Here is what it was doing, ran great before the weekend and in the paddock, good idle, etc, go out on the track, runs great for 3 or 4 laps, than just dies,acts like you hit a rev limiter,keep your foot in it will move but continue to die and lose speed, take your foot off the pedal and it just dies, wont restart, will fire but just dies after it goes to 2 to 3000 rpm
    water temp was under 180, oil temp was normal. EGT 1350 to 1400
    Toe the car in, and push it under the canopy wait 5 minutes more and the car starts and runs great, the idle some times jumps up 500 to 800 RPM's
    This happened all weekend both days, we changed the following to no avail
    Control Pressure Regulator
    Coil
    Wires, plugs
    Oxy sensor
    Pulled the fuel pump relay and ran a jumper
    None of those worked?, anyone have anything similiar? or know a hint or fix?
    thanks
    NC
    682
    Coil
    Wires, plugs
    Oxy sensor
    thanks
    Been there, done that, got the t-shirt and burnt pistons. From your symptoms, my bet is that you have a dead or dying fuel pump. Has the pump ever been allowed to run dry?
    What I think happens is that the pump works OK under full load until it overheats and then loses pressure. I swapped the pump out and problem was solved. However, if it is allowed to run dry, even for just a few moments at a time, it will die again soon!
    Welcome to GP!
    MC
    Mark Coffin
    #14 GP BSI Racing/Action Digital/Airborn Coatings/Krispy Kreme VW Scirocco
    Columbus, Ohio
    53
    Thanks Mark, that is where I was leaning, just didnt have a spare at the track so couldnt try it.
    No, the pump has not been allowed to run dry, at least not since I have had the car, 4 years.
    My biggest problem is being able to duplicate the problem, since it seemed to only do it under load, if I test it using the Bentley, will that tell me the pump is going or is bad even not under a load? just curious?
    thanks for your help
    NC
    682
    The problem only showed up under load, after 3 or 4 laps. In the pits, it would show perfect pressure, and fuel delivery. I kept trying other stuff, but eventually figured out it was the pump.
    Swap the pump out, and see if the problem goes away. My bet is that it will.
    MC
    Mark Coffin
    Flagtown, NJ USA
    6,335
    I agree w/ Mark, I'd bet it's the pump.
    SCCA 279608
    Charlotte, NC USA
    168
    Nope, believe the problem is the "flux capacitor".....
