Page 1 of 2 12 LastLast
Results 1 to 20 of 33
Thread: ECU rules applied to VWs
    Ottawa, Ontario, Canada
    665
    Default ECU rules applied to VWs
    For those who haven't noticed, there's an interesting discussion going on in the Rules&Regs section re: cleaning up the Engine Control Unit (ECU) rules. I'd like to point out that the current rules make it much harder and/or more expensive to tune a VW than to tune many other makes. This is because VW uses Mass-Airflow (MAF) meters while others use simple Manifold Absolute Pressure (MAP) sensors.
    I like doing my own tuning. I don't want to be at the mercy of the chip tuners, and I don't have enough budget for an expensive ECU (e.g., Motec more than $3000). There are cheap alternative do-it-yourself ECUs (e.g., Megasquirt less than $200), but they use MAP sensors. The current rules do not allow the addition of a MAP sensor or wire.
    8,607
    So what to do? I don't truly believe that there will be any changes in the ECU rule in the foreseeable future. Is there room for a reasonably affordable, effective solution for the Motronic VWs?
    665
    Well, there *might* be room, but it would be a heck of a lot easier if we could use the cheap MAP-based systems. I think it really does take something on the order of a Motec to make use of a hotwire-type MAF as used on the Golf 3.
    I have been trying to "adjust" the OEM Bosch computer. Some people know how but refuse to share. I've spent $900 already on the latest VAG-COM and a few different chips, and countless hours trying to figure out alternatives, but I'm still not able to even adjust the minor adaptation values. It seems that the chip makers should have freed this up for us, but chose not to so they could keep selling us more chips instead -- or..., maybe the chips have to be locked for emissions reasons -- not certain. To be honest, I'm a bit frustrated over the whole thing... For this much effort and expense and I still can't turn off my smog pump, tweak my fuel mixture or adjust my max speed cutout.
    8,607
    Did you see http://forums.vwvortex.com/zerothread?id=1191064 ?
    It sounds like you are operating on the assumption that aftermarket chips don't have limits on the adaptation channel values..."
    I am at the VERY bottom of the learning curve on this issue but have at least the tiniest clue about how this stuff works in general.
    How about the idea of creating a usegroup kind of organization to distribute the load and share information on this front?
    I could even see cutting loose with some development dough if there was a chance that we could come up with something that could be commercialized somehow.
    Oct 2003
    Portland Oregon
    102
    Eric
    I have access to the information you may need. My sponsor does chip devolpment with a dyno and works closely with a well known tunner. Let me do some poking around and see what I can find. It would help if I know the ECU part number, what car it is going into and what you are after. It will then take some O2 sensor voltage readings to trim and do any final adjustments.
    Jon Bonforte
    Portland Or
    ICSCC #99 EP
    [This message has been edited by VW16VRacer (edited November 05, 2004).]
    665
    Kirk: Thanks, I have seen that one. Unfortunately, it only works on 2001.5-2003 Golf 4 cars/ECUs (Bosch Motronic 7.x) that happen to have a bug (or back door) in the software (specifically, the KWP-2000 protocol). Revo's Lemmiwinks program only works on those cars. Our Golf IIIs don't have that(OBD 1 is Bosch Motronic 2.9; OBD2 is Bosch M5.9). However, I scoured the Earth and came up with the following 4 "secret codes" that may gain some minimal access to *some* of the Golf 3 ECUs basic adaptation values:
    11463
    07825
    12233
    01283
    I haven't tried these on any of the 2.0s yet (I have '95, 96 and 97 ECUs), but the last one did allow me to reset the factory default adaptation channels on my 97 VR6. I still don't know what the other 7 adaptation channels control (just that the first does a reset of the others), but I believe that one is an idle speed offset, another is probably the road speed limiter, and there are probably a couple of fuel trim values too. I'm hoping that one turns out to change ignition timing offset, but not too optimistic at this point. Even with a chipped ECU, the adjustment range for the second channel was only from 123-133 out of what should have been 0-255. I think it may have changed the idle speed about 40 rpm (123 vs. 133), but not positive. The default was 128.
    Jon: That sounds very exciting! Please do check with them and try to plead our case. I would certainly be willing to pay for enough info to allow us to tune the cars at the track (I would have no problem adding an eprom burner to my toolbox, but would of course prefer to flash them in-situ through the OBD port). The project car is starting off as an early 95 Golf with OBD1, but I do have enough stuff to convert it to 96 or 97 OBD2, if that would be easier to tune (which looks likely at this point).
    P.S. -- I can copy down the various ECU numbers tomorrow. I might even have a 98 kicking around too.
    [This message has been edited by Eric Parham (edited November 06, 2004).]
    8,607
    From that same source...
    Channel 1: Additive Engine Idle Speed Offset
    This channel allows one to adjust the engine idle speed in steps of 10
    rev/min.
    Typical VAG control range : -50 rev/min to +50 rev/min
    Maximum possible control range : -1280 rev/min to +1270 rev/min
    Channel 2: Tweak on fuel enrichment based on increasing loads (i.e. accel pump)
    This channel adjusts a fuel enrichment term that is proportional to load
    rate of change and that acts to enrich full when the engine load is
    increasing. This is equivalent to an accelerator pump function
    Typical VAG control range : 100% to 110%
    Maximum possible control range : 0% to 200%
    Channel 3: Tweak on fuel enrichment based on decreasing loads
    This is very similar in function to channel 2 but adjusts a term
    that works to decrease fuel when engine load is decreasing.
    Typical VAG control range : 90% to 100%
    Channel 4: Tweak on Startup Fuel Enrichment
    This adjusts the startup fuel enrichment term.
    Channel 5: Tweak on Warmup Fuel Enrichment
    This adjusts the warmup fuel enrichment term.
    Channel 6: Lambda Regulation
    This tweaks a lambda regulation system's narrowband oxygen sensor
    cycle time in steps of 10 milliseconds.
    Typical VAG control range : -100 ms to +100 ms
    Maximum possible control range : -1280 ms to + 1270 ms
    Channel 7: Additive Offset On Speed Limiter
    This is allows one to adjust the speed limiter in steps of 1 kmh.
    Typical VAG control range : 0 kmh (no adjustment allowed)
    Maximum possible control range : -128 kmh to + 127 kmh
    Channel 8: Secondary Fuel Tweak
    This adjusts the main fuel term.
    Channel 9: Additive offset on ignition timing angle
    Allows one to shift the ignition timing angle up or down in steps of
    0.75 degrees.
    Typical VAG control range : No adjustment allowed
    Maximum possible control range : -96 Degrees to +95.25 Degrees
    Channel 10: Primary Fuel Tweak
    This adjust the main fuel term.
    Maximum possible control range : -25% to +24.8%
    Channel 11: Unused
    Maximum possible control range : -128 to +127
    Channel 12: Specified Engine Load Scaling Factor (Turbocharged cars only)
    This factor allows one to scale the specified engine load. The default
    value comes set at the maximum value, so specified engine loads can only
    be reduced with this adaptation channel.
    Typical VAG control range : only 100% allowed (no adjustment allowed)
    Maximum possible control range : 0% to 100%
    Channel 13: Control Bits
    These control bits affect engine idle control.
    Typical VAG control range : limited to 2 control bits
    Maximum possible control range : 8 different control bits can be set
    or cleared
    Channel 14: Additive Offset To Idle Torque
    This channel allows one to raise the minimum torque maintained at idle.
    Typical VAG control range : 0 to 31 (arbitrary units)
    Maximum possible control range : 0 to 255 (arbitrary units)
    I'll start the process on my end by checking the numbers on my two ECMs as well.
    665
    Just spent some time searching for my extra aftermarket chips -- no luck yet but I'll keep looking tomorrow. I'll try to check all of my ECUs too, with and without the various chips I've got. BTW, our M5.9 ECUs only have a total of 8 adaptation channels (0-7 in VAG-COM) and ch 0 is the reset, but I just noticed back on that revo source that many were not used on the naturally aspirated golf 4s, so maybe the ones that were might be the ones we got on the golf 3s. Might be a headstart, at least, to see if our channels 1-7 correspond to the M7 channels 1-3, 7-8, 9 or 10, and 13 or 14, as above.
    p.s. -- the defaults on my chipped vr6 were:
    ch 0: 000 (reset)
    ch 1: 128 (could adjust from 123-133)
    ch 2: 128
    ch 3: 128
    ch 4: 128
    ch 5: 128
    ch 6: 0
    ch 7: 1
    8,607
    I posted something in the VAG-COM forum on the Vortex, and got a bite. Take a look at...
    http://forums.vwvortex.com/zeropost?cmd=ts...show&id=1671365
    How big is CT, again?
    Flagtown, NJ USA
    6,335
    Kirk,
    Contact me off line, I need to speak w/ you about something.
    SCCA 279608
    665
    Thanks Kirk, I have already made contact with Jeff. He shot down the non-invasive flashing idea for the Golf 3s, but we think we can work something out to get a basic map built and tuned with an in-car emulator. I may change my ice racing steed to a 2.0L OBD2 setup so we can try out tuning with the emulator. The emulator and modified computer box (hole for emulator connection)would have to be swapped out for a burned chip in a stock box for any SCCA racing.
    I don't want to put my new Golf 3 on the ice because it would look like a war victim before next Spring (ice racers are generally better skilled but less lucky than SM drivers, for example), but I'll see if I can find something suitable (the ice racing cage rules are even stricter than IT).
    Anyone know how to reach Tim Mullen from MA?
    665
    BTW, my costs associated with tweaking the stock ECU are creeping up on 10x what the cost of a Megasquirt and MAP sensor ($150)would have been, and will have well exceeded $2000 by the time it's workable. Oh well, I'll stop complaining for now. Cheers!
    8,607
    My ECM numbers are as follows:
    021 906 259
    0 261 204 831
    [10.01.98]
    037 906 259 J
    0 261 204 514/515
    [07.06.97]
    The last I assume is a date. What is the significance of the others? Hardware P/N and a designation for the software version???
    EDIT - 1996 GTI 2.0, OBD2, M5.9 engine management. I'm looking for a higher rev limit so I've got more latitude to pick shift points, and whatever area under the torque curve I can get. I'm less likely to be tuning at the track but would like to be able to optimize on the dyno without having to be swapping chips in and out...
    [This message has been edited by Knestis (edited November 06, 2004).]
    665
    Originally posted by VW16VRacer:
    ... It would help if I know the ECU part number, what car it is going into and what you are after. ...
    Jon,
    Although the ITB project car is an early 95 Golf GL 2-door with OBD1 (M2.9), I have enough stuff here from a 96 to convert it to OBD2 (M5.9). I haven't checked for the M2.9 ECU #, but my 96 GTI 2.0 has Bosch ECU No. 037-906-259 (no letter version) and I have another ECU out of a 97 Jetta with Bosch ECU No. 037-906-259-N. I also have at least a Neuspeed P-chip that's supposed to work in one of these, I think.
    What am I after? I want as much control as possible over the program and its maps, and I'd like to be able to tune it properly for various changes specific to a built ITB engine that will be run at various tracks in all types of weather and with potentially inconsistent fuels.
  15. #15
    665
    Using Kirk's format, my OBD2 2.0L ECU numbers are:
    96 ECU:
    037-906-259 (no letter)
    0-261-203-719/720
    06.02.96 (this is in dd/mm/yy format)
    97 ECU:
    037-906-259-N
    0-261-204-635/636
    05.05.97
    Kirk,
    Is the one that does not begin with "037" also a Bosch?
  16. #16
    8,607
    Yup. "Bosch - Hecho en Mexico"
  17. #17
    Oct 2003
    Portland Oregon
    102
    Eric
    I have fowarded the information and should know in a day or so. Post or private e-mail?
    Jon
  18. #18
    Oct 2003
    Portland Oregon
    102
    Eric
    Jon
  19. #19
    665
    Thanks. It's fine with me to post the info here. I guess the only reasons not to would be up to the tuner. I noticed that my email won't show in my IT.com profile. It's [email protected]
  20. #20
    New York, NY, USA
    451
    From ETKA I got the following part numbers:
    037 906 258 AS
    >>>1H-S-999 000
    "only KD" (don't know what this means)
    037 906 259 and 037 906 259 J
    1H-T-000 001 >>> 107 409 (obd1)
    037 906 259 D
    1H-T-107 410 >>> (obd2)
    037 906 259 E
    1H-T-107 410 >>> (obd2) "California"
    Hope this is of some use.
    Eric, how is it going?
    Dave Z
