I am considering fabricating a new cage for my A1. A few questions/thoughts in regards to the subject. 1) Should the rear main hoop bracing tie into the top of the rear shock mounts? 2) Is it legal to mount the rear hoop in the "pockets" that are just behind the front seats? Is this area considered the floor of the car? I am tall (6'4") and the extra leg room would be nice. 3) The car was registered prior to '95, however, fabrication of a new cage would require adherence to the 100 square inch rule regarding mounting plates. Correct? 4) With the exception of the heater, is it legal for the dashboard to be gutted internally? Also, does a replacement gauge panel have to fit in the original OEM space? 5) Should the forward braces (+2 option) tie into the front wheel wells as high as possible? Or would projecting the tube downward to the well from the windshield angle of the front brace be better? Thanks for your input on this subject. One other thought, unrelated to the cage. Is it legal to use the washer bottle as a breather?
