Hi, this is a bit OT for the IT website, but maybe someone can help me out. I have a limited prep H Production (1976 A1) Scirocco and I'd like to convert over to rear disc brakes. What is the easiest/best rear disc brake conversion to do? I guess I need a complete rear spindle setup from some slightly later A1 car that has the rear discs and it will bolt right up? Which ones will clear the 13" x 6" wheels? Will the stock master cylinder for the drum brake car work OK with the disc brakes or do I need to change that too? I'm currently using a Wilwood proportioning valve in the rear circuit so I can control the pressure. What pads would be appropriate? A street pad like Hawk HPS or Hawk Black or a Porterfield R-4S? I'm using the Porterfield R-4 compound in the front. Thanks in advance!
