Results 1 to 6 of 6
Thread: Welding a Diff
    Tucson, AZ USA
    240
    Default Welding a Diff
    Whats the best way to go about welding a diff. for an A1 Rabbit. I have heard of people breaking pieces off the diff because it wasn't done right. TIA
    Sam Rolfe
    TBR Motorsports
    #85 ITC VW Rabbit
    #85 GP Scirocco
    Apr 2001
    Belmont, CA USA
    1,098
    Sam, I've got a locked 4 speed with a 3.76 R&P if you want it. It's my 2nd spare.
    Tim Linerud
    San Francisco Region SCCA
    #95 GP Wabbit
    Maryland Heights, MO USA
    461
    A bad welding job is worse than an open diff; you will destroy it. Seen it happen.
    Lesley Albin
    Over The Limit Racing
    Blazen Golden Retrievers
    Nov 2001
    Bunker Hill,WV.
    614
    Sam
    When we make our welded diffs we do the following:
    after fully cleaning the diff
    weld the spider gears together,in the corners of each meeting of spider gears. then make two plates that would fit down in the open space on either side of the diff. weld the plates, one to each side of the open space on either side of the diff.
    Viola! you have a welded spider gear differential. I have had one that has lasted 5 12hour and 3 24hour races with no problems. I have another made this way that is in a car that is now on its second logbook. I am sure this method will work for you.
    dave parker
    wdcr itc#97
    Dick Elliott Guest
    In the Steve Smith how to book (How to build a mini stock pinto)he shows that the best way is to fill (weld) the area between two (2) teeth with brazeing. Then rotate the gear and do the same thing 180 degs from the first place. Do both the gears this way. Brass is used because the book says that arc or mig place too much heat into the gears and will cause failure. I have done several cars this way with nary a failure to date. It can be done on old gears but much easyer on new gears.
    centerville, MN, US of A
    135
    Originally posted by Dick Elliott:
    ... Brass is used because the book says that arc or mig place too much heat into the gears and will cause failure. ....
    I'm not saying this won't work, but the amount of heat put into the differential by brazing is considerably more than MIG. The MIG is much more concentrated too, which may be an issue, but I've done the weld the gears and plates method and it works great.
