Results 1 to 9 of 9
Thread: Spring Rates?
    Feb 2004
    NY
    22
    Default Spring Rates?
    What is everyone using? I was using one front bar with 300lbs springs front and rear. I had a horrible push, so i disconected the front bar and it helped the push, but it had more body roll and the springs felt too soft in the front. To fix it for the next event I have reconnected the front bar so the body roll wont be there, and added two rear bars, all lower bars. What springs should i be using? I was told to get 500's for the front and keep the rear the same, and with all the bars connected the body roll will be minimal and the springs should be ok. what would all of you suggest.
    84 gti itb
    [This message has been edited by 1990whiteg60 (edited April 23, 2004).]
    Tucson, AZ USA
    240
    It depends on what you are running. On my ITC rabbit I run 650lbs springs in the front with a lower stress bar(no upper bar) and in the rear 400lbs springs and two Shine tubular bars. Hope this helps
    Sam Rolfe
    TBR Motorsports
    #85 ITC VW Rabbit
    #85 GP Scirocco
    Nov 2001
    Columbus, Ohio
    53
    I have a 83 GTI in ITB, I run 650 fronts and 400 rears, no front bar and 1 rear bar.
    Just keep adding more rear spring until the push goes away. You'll end up with a stiffer car (less body roll), and the right balance.
    I would try springs at least 10 - 20% stiffer (ie. 350's or even 400s) -- make a big enough difference that you can feel it.
    Nov 2001
    SE Michigan
    268
    Im going with 550 front 350 rear with a rear bar on my A2.
    Doug
    87 Golf GTI
    [email protected]
    Mar 2004
    Columbus, OH
    35
    I have 450 lb front springs, 475 lb rear springs, no front bar and a big rear bar.
    Kevin
    '85 VW GTi
    Sep 2002
    Stamford, Ct
    96
    600 front no sway bar, 400 rear Shine bar
    Oct 2003
    Portland Oregon
    102
    450lbs front, latest BSI valving in front Koni double adj, no bar.
    475lbs rear, BSI revalved rears, BSI rear bar.
    Weld in camber plates.
    Shaved Toyo 205-55-14
    89 16V Golf
    KICK ASS set up!
    Flagtown, NJ USA
    6,335
    I ran 650F/400R, no front, 2 rear bars w/ Bilstein Group I race and re-valved Sports in the rear. Also had the K-style front lower stress bar. Car was neutral to slightly loose on a dry track w/ hot tires. Was _very_ loose on a wet track or on cold tires. Just take one of the rear bars off.
    SCCA 279608
