Originally posted by MiniStocker:
Hello, The car I'm working with is a circle track car and the track is requiring me to add approximately 350lbs to get to 2100 lbs. with driver included.
My question is, what is a good front to rear percentage? I've ran Mustangs in the past and they really liked rear weight in the 51%-52% range. With front wheel drive, I'm not sure where the weight should be. I've got a locked external ratcheting differential and GoodYear slicks. I have little wheelspin coming off the corners, but lift the LR wheel about 6". Should the weight go in the LR? LF? If so, how much? Should I try for a 50-50 front-rear split?
Hope I've been technical enough in my explanation, you guys always give the best tech...
Scott
