Boosting the fuel pressure is only helpful for forced induction, and even then it must be in combination with control pressure mods (e.g., increased control pressure except under boost). A better idea for IT might actually be to reduce system fuel pressure in order to be able to run a lower control pressure for the same mixture strength, and thus reduce the downward force that the incoming air must overcome at the fuel distributor plate. Unfortunately, this leads to other problems...
