Results 1 to 10 of 10
Thread: spring rates
    Oct 2002
    16
    Default spring rates
    What spring rates are being used on Rabbits out there? We got our car used and don't know what rate springs we have but I assume they are soft because we get a ton of body roll in the turns. We run no front bar and a big rear one with Koni struts and shocks. The car handles well and we get good tire wear. any suggestions?
    169
    The local wabbit in our area runs #500 front and #350 rear. HTH
    Steve
    Apr 2001
    Belmont, CA USA
    1,098
    I use 500 front and 300 rear. Bilstein sports all the way around, with Ground Control Camber plates in the front, and the BSI shims in the rear.
    With slicks, 1 degree negative camber up front, and .5 degree negative in the rear.
    0 toe up front and 1/8 toe in out back.
    Locked diff as well.
    Tim Linerud
    San Francisco Region SCCA
    #95 ITB GTI, GP for 2002
    Tucson, AZ USA
    240
    Depending on who you talked to the rates are all over the place. In my ITC Scirocco I am running 650# in the front and 350# in the rear, though i could probably go to a 450 in the rear. The car has always handled great, but I have heard of others who go the complete opposite, with softer springs in the front and stiffer in the rear. It all depends on what you are runnign for bars, I was running two of Shine's Tubular bars. Hope this helps
    Sam Rolfe
    TBR Motorsports
    #85 ITC VW Rabbit
    #85 GP Scirocco on the way
    #11 GP Scirocco on the way
    Flagtown, NJ USA
    6,335
    I ran 650#F/375#R, but will be upping the rears to 450#. No front bar, and 2 rear bars, Billstein race struts.
    MARRS #25 ITB Rabbit GTI
    SCCA 279608
    Spiro13 Guest
    For you racers running high front spring rates - 500 to 650. Are you running LSDs or locked diffs? I read that if you run an open diff the spring rates should be softer to increase grip. Any thaughts on this?
    Tony
    ITC #0
    NC
    682
    Just to be different: I ran 325# all around with a 1" rear OPM rear bar on my ITC Scirocco. Always with a limited slip. I tried the stiffer front setup, but it made the car push too much and I couldn't dial it out with shocks. I did have double adjustable konis on the front, single adjustable konis on the rear.
    On the GP car, I started out with 325# front and #400 rear, NO BAR on the rear. The balance was good, but not stiff enough. I'm experimenting now with raising them proportionally front/rear. Remember though, this is with slicks which have more grip. s
    YMMV,
    MC
    Flagtown, NJ USA
    6,335
    I started w/ an open diff, went to a Quaife, and will probably go w/ a spool for next year.
    SCCA 279608
    Oct 2002
    16
    I run a Quaife plus two of our drivers are over 200 lbs.
    Oct 2002
    wilmington,nc,usa
    25
    Dont know if this will help but for what it is worth, I run 450fr/350r, am looking to go stiffer(400#) to the rear. Balance isn't quite right. With the corner weights right on, car sits a bit higher in the rear than I prefer, tends to get squirly when I'm being drafted close at high speed. other than that it handles like a dream. Stock diff/gears (open), lots of camber up front (with no tire wear problems and degree 1/2 in the rear.
