Results 1 to 5 of 5
Thread: Quaife'sand tire ware
    Jul 2001
    Scranton, PA
    33
    Default Quaife'sand tire ware
    I have had a Quaife installed and after
    Two solo 1 events and two solo 2 events
    I have alot of wear on the drivers side
    and very little on the otherside.
    Is this normal wear?
    Is this on a clockwise or counter-clockwise track (or tracks)? Is that likely to have been a factor?
    Kirk
    Jul 2001
    Scranton, PA
    33
    both ways.
    the wear on the driversside is 3x that on the
    right,
    vernon,CT. U.S.
    152
    Spike,
    I would be looking at something other than your diff for tire wear like that. What kind of negative camber are you running?
    How about toe?
    drew
    Jul 2001
    Scranton, PA
    33
    I was going to check toe & camber this weekend.
    But when I set up the car I had 1/8 total
    toe out and 2.5* camber.
    I thought about that at first but after looking at the amount of wear and the amount
    of use I think there might be something wrong with my Quaife.
    It's as I only have one wheel drive.
    Thanks for you help
    Spike
