Results 1 to 6 of 6
Thread: thermal switch..2prong vs 3prong?
    Dec 2001
    Manitoba,Canada EH?
    25
    Default thermal switch..2prong vs 3prong?
    Okay, lame question..but on your typical 80's VW rad (88 Scirocco non-AC 16v in this case) whats the diff with the 2 prong vs 3 prong thermal switch? What does the 3rd prong function as?
    thx
    Matt
    Charlotte, NC USA
    168
    Three terminal connectors are used with two-speed fans. Low speed (continuity on switch terminals 2 & 3) comes on between 198 to 208 degrees (F). High speed (continuity on switch terminals 1 & 3) comes on between 210 to 221 degrees (F).
    Flagtown, NJ USA
    6,335
    Dr. Ryan is right as usual!
    MARRS #25 ITB Rabbit GTI
    SCCA 279608
    Dec 2001
    Manitoba,Canada EH?
    25
    Thanks guys. Should I assume that with the 2 prong..the fan comes on between 198 and 208 then?
    thx
    Matt
    Flagtown, NJ USA
    6,335
    No, it actually depends on what the switch is set for. I've got a 2-prong that's set for 180.
    SCCA 279608
    Dec 2001
    Manitoba,Canada EH?
    25
    Ahh yes...now that you say it..I seem to recall there being a ' 90 95 ' on the plug..so it'll turn on at 95, off at 90....which my handy conversion dealie says 203 and 194 fahrenheit.
    thx!
    Matt
