Results 1 to 15 of 15
Thread: VW Transmisions
    Apr 2002
    Portland, ME, USA
    33
    Default VW Transmisions
    I am trying to sort out the parts codes on the 020 transmissions so I can figure out which gear ratios the stack of trannies that I inhgrited have. Any guidence would be greatly apprciated.
    Erik
    NC
    682
    Erik,
    Check here:
    www.scirocco.org and look under "Gears".
    Mark Coffin
    Aug 2001
    Gloucester, ON, CA
    109
    Apr 2002
    Portland, ME, USA
    33
    Thanks. Both sites are great info. Now I can get to finding a close ratio 5 speed so I can get out of 3rd gear. Thanks again.
    Aug 2001
    Gloucester, ON, CA
    109
    4K or 9A...
    8,607
    Remember that you can only up- and back-date among years/models on your specific spec line. I am not the VW P/N expert but if the 4K and/or 9A came in, say, an '83-84 GTI (listed in IT, it would not be a legal swap into a '75-80 ITC bunny or Scirocco that never had it. Just a hypothetical example but illustrative perhaps...
    Kirk
    239
    Originally posted by rmicroys:
    4K or 9A...
    Actually all (most?) 83 GTIs came with a '2H' code box. close ratios and 3.94 R&P -similar to the 4K.
    PJ
    83 Rabbit GTI - future ITB
    Apr 2002
    Portland, ME, USA
    33
    OK. These last two replies seem to take most options away. The FF and GC Trannies that seem to have originally come in my 1980 ITC Rabbit are basically the same. I am assuming the up/backdating applies to final drive gears as well. Almost every driver I spoke with at Pocono, Limerock, and NHIS are catching 4th at some point. Is my car that underpowered or am I missing something?
    [This message has been edited by ITC Mercury (edited July 10, 2002).]
    Flagtown, NJ USA
    6,335
    You can run whatever R&P ratio you want, as long as it fits in a stock case. The ITC Rabbits/Sciroccos all have the wide-ratio boxes.
    MARRS #25 ITB Rabbit GTI
    Jul 2001
    Janesville, Cheeselandia
    43
    Knestis, can you tell me what years/models are listed on the same spec line as an 88 Jetta 2 Dr? Thanks!
    Flagtown, NJ USA
    6,335
    From the '02 GCR ITCS 44, ITB VW Jetta,GL,GLI '85-'91
    8,607
    Bill beat me to it but do yourself a giant favor and don't do ONE thing (or one MORE thing?) to the car before getting a rule book. People - even the wizards here at it.com - will give you all kinds of wrong info about what you can and can't do and none of them will come to your rescue if you are confronted by a rules NERD and protested.
    You probably already know about the Jetta "Coupe" rare sheetmetal issue, right?
    Kirk
    Aug 2001
    Gloucester, ON, CA
    109
    I was going to mention that earlier, I would refrain from making a 2dr Jetta racecar. I race one in Ontario, Canada and had a tough time finding a suitable car to take a rear panel to repair crash damage that I sustained when I had a 'moment' in corner two. The damage at least wasn't bad enough to warrant grafting another rear body on to the racecar, we managed to put it on the rack and pull it straight.
    After this experience, I would strongly suggest using a 4dr chassis.
    Ottawa, Ontario, Canada
    665
    Yes, GC and FF are correct for 1980, but you're also allowed anything from 1975-1979, right? From memory, I think those years included GY, GP, GH, GF, GC, FO, FK and FF codes. Some of those codes may have been diesels or pick-ups, but you get the idea. In addition, there were several versions of FF, and probably at least two versions of GC. There's info in the Haynes and Bentley manuals for that era, as well as the microfiche, but I wouldn't trust all of it. Better to count teeth, or at least to count turns of the input shaft. For the 4-speeds, there are at least two 3rd gears (1.37 and 1.29), and at least two 4th gears (.97 and .91). Same goes for the 5-speeds, plus either a .76 or a .71 5th. If using an FF, be aware that they drastically changed the ratios without changing the code sometime between late 1980 and early 1981!
  15. #15
    8,607
    ...with the notable exception of those from the diesel or pick-up.
