Custom ign coil wire
I'm experimenting with a crane fireball coil this year that I got from a friend. Unfortunatley he didn't give me a coil wire. The coil has a GM style outlet and I need a wire that has a gm style plug on one end and a Beru pin style plug on the other. Or can you get different outlets for the coil itself? Anyone know of any shops where I can get one of these made up?
thanks
Steve
87 ITB Scirocco
Steve
I run the Fireball ignition including the coil. I went to a local speed shop and they had all differnt types of coil wire ends. I picked the one I needed(can't recall what brand)put it on the coil wire I had and it works fine.
Tony
ITC #0
- You may not post replies
- You may not edit your posts
Forum Rules
