Quickest ratio A1 steering rack?
trying to find out what,if any,is the quickest factory A1 rack. Thanks,John
The manual racks (aluminum and steel) both had the same ratio, although one may have had slightly more total travel. The power racks (aluminum and steel) had slightly quicker ratios, and I believe that one of them was non-linear (i.e., the ratio got quicker off-center). Stay away from the aluminum racks, the slight weight savings is NOT worth the reduced durability (they often crack), IMHO.
- You may not post replies
- You may not edit your posts
Forum Rules
