Results 1 to 7 of 7
Thread: 87 Jetta GL - ITB or not 2B??
    Feb 2002
    Aurora, IL USA
    2
    Default 87 Jetta GL - ITB or not 2B??
    Quick question
    I currently own an 87 Jetta GL 1.8l 8V, 4 door with 5 spd. Should I prep a 4 door for ITB, or start looking for a 2 door GTI / Golf.
    I would appreciate any direction.
    Pittsburgh, PA
    1,181
    The Jetta can be made to be every bit as competitive as the Golf. The weight distribution is better and the aerodynamics are too. Find a GLi wing for the trunk.
    We ran against a guy at the Glen last year who was quicker than all the Golfs.
    Feb 2002
    Aurora, IL USA
    2
    A 4 door??
    8,607
    The Jetta is listed at 2330# - 50 more than the Golf - and the CR is only 8.5:1 (vs. 10 for the Golf). Howzat? The question would be can you get a 4dr to that weight - I don't know the answer right off hand...
    Kirk
    [This message has been edited by Knestis (edited February 09, 2002).]
    Omaha, NE
    316
    Wasn't there a Fastrack correction for the Jetta that brought the compression up to 10? I believe it also corrected the wheelbase measurement from 94.5 to 97.3. If not, it needs to be!
    Ralf
    Pittsburgh, PA
    1,181
    The Jettas and Golfs are 8.5:1
    Uless you race a GLi or GTI.
    Or you run a Digi car 87.5 and later.
    Flagtown, NJ USA
    6,335
    First off, I believe that the CR of the Jettas was corrected to 10:1. Second, I belive that through the update/backdate rule, you can make all the ITB A2 cars the equiv. of the GTI/GLI.
    MARRS #25 ITB Rabbit GTI
