Results 1 to 4 of 4
Thread: VW Circlip tool
    centerville, MN, US of A
    135
    Default VW Circlip tool
    Any one know a good place to get the tool for the VW circlip's used in the tranny? Tired of trying to use a standard tool that keeps poping off.
    Mark LaBarre
    Pittsburgh, PA
    1,181
    All Sears stores carry them.
    Also KD tools has them and most parts stores can get KD.
    Jan 2002
    Baltimore,MD,USA
    2
    I havn't been able to find the VW tool. What I do instead is destroy the old one while removing it (usually)
    To install the new one, use a Dremel Tool with the reinforced cut-off wheel to cut small slots in the two open ends of the clip. (it only takes a few seconds to do this) Then use a regular circlip tool to hold the clip-ring open. Sears sells an inexpensive circlip tool that has a screwdriver-type handle that holds the jaws of the tool open in one fixed position. It is usually in the automotive section, or next to the other, conventional circlip pliers.
    The modified clips are SUPER easy to remove, as well.
    good luck.
    -tom
    Flagtown, NJ USA
    6,335
    The clips are single-use anyway, but I agree, they're a PITA to get off w/o the proper tool.
    MARRS #25 ITB Rabbit GTI
