Page 1 of 2 12 LastLast
Results 1 to 20 of 33
Thread: Gaining weight
    Oct 2004
    Northeast
    7,031
    Default Gaining weight
    Let's say hypothetically, that YOUR car's minimum weight was raised by 100-150 pounds.
    What would you do to make weight?
    Add gas?
    Add cage?
    Put some interior back in?
    Add it all in legal ballast?
    All or combo of the above?
    It seems simple to me but I wanted some creative minds out there to provide feedback...
    Andy Bettencourt
    New England Region, R188967
    www.flatout-motorsports.com
    Oct 2001
    Oregon City OR.
    1,550
    For that much weight you could get a girl friend....
    Or I would add ballast and tubing..and a cool suit.
    Renton, WA USA
    1,625
    I'd still have to find about 25lbs to lose...
    I'd definately do some cage improvements. Could also use the money I'd save on NOT having to buy a Carbon/Kevlar seat and other high dollar ultralight pieces to pay for GAS!
    Definately easier to prepare a car that DOES NOT have to obtain a really low minimum weight...
    Darin E. Jordan
    SCCA #273080, OR/NW Regions
    Renton, WA
    ITS '97 240SX
    Mar 2001
    Connecticut
    7,381
    Order of priority:
    - Maximize stiffness of the cage, especially down low. Make better anti-intrusion bars, better foot protection, etc.
    - Add fuel. FWD cars need the rear weight bias. Maybe even add a large fuel cell.
    - Add interior pieces to reduce noise and heat, especially down low. Carpet, carpet insulation, sill trim, etc.
    - Add ballast.
    If I were - hypothetically speaking - dealing with an ITS/SM crossover, I'd probably focus on things easily removable. Fuel, bolt-in cage parts, carpets, and additional ballast.
    Jul 2002
    Billerica, MA
    272
    I would prefer to add ballast over anything else. Fuel is expendable, while it would be fine to add fuel for most sprint races, the car should be able to roll over the scales and make minimums dry. It cars do run enduros, etc. Additional cage would cost more to those that cannot weld. I might also put the spare tire back in or something to that effect.
    Jason
    ITB 17 (NER SCCA)
    VW Scirocco
    Apr 2002
    Houston, TX USA
    2,555
    Eat more doughnuts?
    George Roffe
    Houston, TX
    http://www.nissport.com
    Roswell, GA
    219
    Optimize the cage for stiffness.
    Depending on where I would like the weight to balance the car, I would look at what I could legally replace/add/change.
    For example, a heavier exhaust puts the weight really low.
    Sturdier hardware for mounting the seat.
    A heavier battery for that light right rear corner.
    Ballast.
    Gas.
    Heavier gauge bulkhead for dividing the driver's compartment from fuel hose.
    Sound/heat insulation like carpet, etc
    Ony Anglade
    ITA Miata
    Sugar Hill, GA
    Nov 2001
    Halifax, Nova Scotia
    639
    I would definitly add cage....I'm not hung up on trying to make my car as fast as possible. Safety is my first priority.
    Buffalo, New York
    2,942
    Stainless exhaust (full length)--nice and heavy and DOWN LOW in the middle of the car.
    Cheaper solution--Put your spare tire and passenger seat back in.
    Jul 2001
    Charlotte, N.C. USA
    252
    I like Pizza myself.
    Russ
    Oct 2002
    Concord, NH 03301
    700
    Breath a huge sigh of relief to know that the car is finally able to make the minimum. The cry when I think of what that does to the tires.
    Then ballast & quit agonizing over how to build things from plastic & aluminum. Ballast is the easist thing to tune to match driver/fuel/tire weights that can change.
    Oct 2002
    newington, ct
    4,182
    This brings up another question I've been thinking about. During the offseason I've been having some fun with the car (or not with the oil leak amoung other things!!) Within the next few weeks I'll be taking it to the scales.
    How close do you get it to the minimum weight? I will be using gas as a ballast and am being on the conservative side with my ending fuel amount. What other very cheap and legal ways are there to add weight where we want it to other than ones already listed here?
    Dave Gran
    NER ITB #13
    '87 Honda Prelude si
    Renton, WA USA
    1,625
    Once the car is race-ready, safe, and basically "done"... I don't see why you wouldn't just take advantage of the ballasting rules to get it to weight... I believe the 100lbs minimum has been officially removed, unless my timing is off and it hasn't been announced yet...
    Darin E. Jordan
    Renton, WA
    ITS '97 240SX
    Jan 2003
    Los Lunas, NM, USA
    682
    >I don't see why you wouldn't just take advantage of the ballasting rules...
    Because by getting creative with allowable items you can improve your weight distribution. As an example, I did an annual inspection on a Miata last weekend where the cage builder used 3/4" steel sheet for the mounting plates on the two right rear mounting points. Very clever, I thought.
    Ty Till
    #16 ITS
    Rocky Mountain Division
  15. #15
    Renton, WA USA
    1,625
    Indeed!
  16. #16
    Loudon Tn
    402
    Various safety items: 1)Reinforce battery and fire extinguisher mounts(use metal plate rather than washer). 2)Add bars to cage(1.5# per ft for .095) 3)Add driver aids(cool suit or helmet blower) 4)suspension reinforcements(sway bar mount or tie bars) You do note that most of these items can be mounted fairly low in the car. I forget where I got the ideas.
  17. #17
    Oct 2002
    newington, ct
    4,182
    Darin, the biggest problem I have with the prelude is how nose heavy it is. I have some weight to play around with and would like a bit more in the rear. Or when you get within 50lbs is it not too important?
    Dave Gran
    NER ITB #13
  18. #18
    Apr 2003
    Charlotte, NC
    78
    Add bars to the cage, add other allowable items (cool suit, fire system, etc.), add back interior. Place them in areas that allow you to improve the weight distribution and lower the CG. If you've got ot add weight, you might as well get some benefit from it instead of just bolting 150 pounds to the passenfer floorboard.
  19. #19
    Jan 2005
    180
    A combination of driver aids and ballast.
    I will be faster and more consistant the more comfortable I am.
    As long as the weight distribution is close, I'd be more concerned with polar momment. A long polar momment (like hanging weight outside of the wheelbase) makes the car much slower to change direction. While, you can tune for an unfavorable weight ditrubtion by controlling how fast the weight transfers to the desired end, within reason.
    Fuel would be my last choice because it moves the opposite direction you want it to, unless you have some elaborate fuel cell with all kinds of trap doors and baffles.
  20. #20
    Oct 2002
    newington, ct
    4,182
    Good points Daryl. What about fuel versus ballast on the passenger side footwell? Again, for a front heavy car. Maybe I'll just split the difference.
    Dave Gran
    NER ITB #13
